Custom Tag Property Set Definition Question
ACA2020
I created a tag that tags a Space for the purpose of determining Occupant Load for that specific Space. Building departments seem to like this.
It has 4 lines that I set up in the Property Set Definitions: The first is a text line that allows you to categorize the type of occupancy. The second is automatic and utilizes the base area of the space. The third is the Occupant Load Factor and is an Integer in the PSD and is also user input. The last line is the Occupant Load which is a formula I created in the PSD which simply divides the Base Area by the Occupant Load Factor. What I'd like to do is to add mere text to the end of that last formula's answer so that it would be more clear that this number is 'per occupant'. I was thinking that I might be able to add a 'suffix' or something that says '/ OC' or similar. I've tried to achieve this to no avail. Attached is a drawing w/ a couple spaces in it, tagged so you can see what I'm talking about. This may not be possible and is not the end of the world if it can't happen.
Thanks in advance!!!
