- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
ACA2016
So... I use spaces to calculate footages and occupant loads. I need a custom block to insert into each room (space) that will indicate the Room Name, Area SF, Occupant Load Factor and Occupant Load. I was thinking that what I wanted was a custom tag, but the more I think about it, the more I think it might make sense to create a small schedule that I just insert into each space. That way I can update it if the room changes. However, the problem is (if you look at the attached) that I'm not sure a schedule can be created the way I want. I want no headings, and no totals. Also, I need it to be vertical instead of horizontal. By that I mean that IF I wanted headings, they'd be on the left w/ the data traveling right as opposed to how it naturally is with headings on top and data traveling down. If you look at the attached it will become clear what I'm trying to create.
I could actually just create a block w/ attributes and edit each one manually, which I suspect is where this will wind up anyway, so I'll probably just start w/ that, but it would be really cool if this worked!
Attached is my construct if anyone wants to see what I'm talking about. I've tagged one space w/ the Space Identifier tag. I also generated my custom Occupant Load schedule for that space. Drawn below that schedule is what I'd like to create. I also included a screen shot of it in case you want to start there and just see what I'm talking about. I also included a screen shot of the PSD I use for my Space Objects.
Thanks in advance to anyone that actually looks at this!!!
Scott
