- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to create a custom slab type that has a chamfer, eg 25x25mm all around, or is it possible to modify a slab after placement to add/subtract this?
I have done this a different way using solids, by creating a 3D solid, then creating a 25x25mm polyline, sweeping that around a path same size as the first solid, then subtracting one from the other, but is the same result possible using the slab function?
I am guessing this is done by editing slab edges or profiles or overhangs but I just cant figure it out.
Using 3d solids is fine for now as I am using acad sections but if I were to use MEP sections I believe it would be better to use the slab function rather than 3d solids. I believe I also may be able to easily convert by solid to mv part for MEP sectioning but still I would like to know if the original query is possible. If this has been asked before, I haven't been able to find the answer, but please feel free to direct me to the link thanks.
Example below:
Idesired result
