For the past few years, my custom dictionary in AutoCAD based products has not worked, for one reason or another. This year, I see that the problem occurs because after each program exit, the selected custom dictionary defaults to none, even though my custom dictionary is set in the options.
Does someone know how to right a lisp routine that would automate setting the custom dictionary to my desired selection. then I could insert it into the Acaddoc.lsp routine.
Hi @mikeshick,
In addition to @pendean's questions, I'd like to know: do you see this error message as well?
Any chance you guys might know autolisp in order to through a command in the autocad.lsp to ensure the custom dictionary always loads at each drawing. Issue was never resolved.
Did anyone see this post about using lisp to set a custom dictionary each drawing load?
