Current layer setting completely ignored when adding new object
dmitriZTSCC
dmitriZTSCC
I'm trying to create layers before working in them.
I create new layers with commands such as
-layer
a
B-Slab
This sets the layer correctly, everything is fine. Then, I go to add a slab with something like
slab
a
<list of points here>
This adds the slab just fine but... it gets added to "Slab-A". Always.
How can I fix this?
David_W_Koch
What Layer Key Style is set current in your drawing file?  What layer name is assigned to the Slab layer key?  Absent any Layer Key Overrides or the assignment of a different Layer Key in a Slab tool palette tool, that layer name will be used when adding a Slab, and, if that layer does not exist, then the layer will be created, using the layer properties specified in the Layer Key Style for the Slab layer key.
Set up a Layer Key Style that has your preferred layer names and layer properties assigned to each Layer Key, and you can skip the step where you define a layer and/or set it current prior to creating any AEC Objects that support Layer Keying.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
dmitriZTSCC
I'm using the default AIA (256-color) key style and a slab is assigned to A-Slab.
I would like, simply, to control the layer to which a created object gets added in my script. That's it. That's literally all that I want. My expectation was that the currently selected layer is the layer the object gets added to but, failing that, I don't mind taking each of the objects individually, one by one, and assigning the layer for each object to what I want. Which seems to be what I need to be doing given the situation.
David_W_Koch
If you have a specific layer in mind for each object type, you can create a custom Layer Key Style that maps those layers to the associated Layer Keys.  If your layering is such that it lends itself to being broken down into components that can then be defined in a Layer Standard, you can also make use of Layer Overrides to modify the layer name if needed for one or more subsets of objects of a given object type.
Or, you can "disable" layer keying by setting the active Layer Key Style to <Current Layer> in the Drawing Setup dialog, Layering tab.2019-05-05_ACA2020_DrawingSetup_Layering_LayerKeyStyle_Current.png
David Koch
Blog | LinkedIn
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
