cREATING A WHITE RECTANGLE IN PAPER SPACE
I need to draw a white rectangle in paper space in order to cover something up which I pasted from another document. The issue is thath when I choose the white or black colour it displays that colout as black on the print.
dbroad
What did you paste?
Depending on the answer to that, you could clip it instead of mask it.  You can also should be able to use a wipeout.  To draw a fillled solid rectangle, you could create a rectangle and then hatch it solid or use the solid command.  The color you probably need is 255.  The plotstyle must plot it in white (or in invisible ink?).
Architect, Registered NC, VA, SC, & GA.
pendean
Community Legend
Community Legend
Color 7 is monochrome 'black', it only displays as white if you have a black background. There is no white ink cartridge in your printer.
Explore using color 255 (and set your plot style table to correctly have this as no-color, since your paper is white), or true color 255,255,255.
Or upgrade your workflow and use WIPEOUT to cover up items in your file: you can set it to match the background color or the colors I noted above.
alison5YAQH
Community Visitor
Community Visitor
I know I'm literally 10 years too late but I googled this error and figured it out on my own.
In paper space, I created a new layer (might not have to) and drew a box on top of what I wanted to hide.
Then filled it in with a solid hatch.
This will automatically be solid black.
Double-click the box/fill area to open the 'Hatch Edit' window.
Change 'Hatch Color' by going to select color > true color > RGB mode > make all values "255" > press 'okay' > press 'okay' again to exit window
It should already show as a solid white box.
My black frame was showing so I selected it and moved it to a hidden layer.
PLOT as you would and none the wiser!
