Two workstations in our office with similar configurations have been having issues opening files recently.
The problem occurs when trying to open a drawing, using either the keyboard shortcut, or the file icon. Autodesk will crash without bringing up the crash dialog popup. The program just closes. There is no indication in the Windows Event Viewer as to any application error. Occasionally, Autodesk will open with the Drawing Recovery Manager, if there were files open during the crash.
From all I can tell, there seems to be some fault in the interaction between Autodesk and the Windows Explorer processes, and I have yet to resolve the situation. It also isn't a consistent error. This may happen anywhere from 1-3 times per day, or as few as once every few days. Any suggestions or help would be appreciated.
Here is a bit more information about our scenario:
All of our project files are located on a local server. We are both running Windows 7 with the latest updates, and Autodesk Architecture 2015 SP2 with all the Hotfixes I can imagine are relating to this issue.
I have installed all the most recent Microsoft updates, inculding those that are relating to compatibility between Explorer and Autodesk.
I have changed both 'Number of recently-used files' in the 'Open and Save' options tab to '0'.
I have followed these steps to ensure that acad.exe runs as administrator after discovering an error in the Event Viewer related to WSCommcntr4.exe
I have recently tried setting CACHEMAXFILES to 0, and will report back to see if this helps.
Any other suggestions? Anyone else with similar crashes?
Thanks in advance!
