copy & paste Xref: can I remain its layer setup (color)?
Message 1 of 9
In paper space, the title block is a Xref, and I changed certain layers' color (from 7 to 9) for specific reasons.
Now for new plans, I need the same title block, so I copied the xref to the new plan's paper space, but those layers' colors ( which i changed to 9) became to original (7).
Is there any way to remain the Xref layer color setup when copying & pasting?
Replies (8)
Message 2 of 9
David_W_Koch
Can you edit the source file for the title block and change the colors of those layers there?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 9
leothebuilder
Set VISRETAIN to 0 (zero)
Reload the xref
Set VISRETAIN back to 1
Message 4 of 9
That is a direct way.
The title block came from client and is shared with other disciplines; we are asked to do so and other disciplines not to; client has their own reasons; can't argue 😞
Thanks anyway
Message 5 of 9
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestions that @David_W_Koch or @leothebuilder provided work for you?
If so, please click Accept as Solution on the post(s) that helped you, so that others in the community can find the answer more easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 6 of 9
that was a direct way which I have thought about; but client has their own reasons to ask us to do so (some other disciplines dont't have to).
Thanks anyway.
Message 7 of 9
If change color in original Xref file itself, yes VISRETAIN would work; but we need to change the color in the file which has xref inserted.
Thanks for your help.
Message 8 of 9
David_W_Koch
If you cannot change the colors in the source file, then you will have to change them afterwards in each file.  You might use a Layer State, a script file or an AutoLISP routine to automate the change, if you have to do this to a lot of files.
David Koch
Blog | LinkedIn
Message 9 of 9
yes, many plans+script; working on it; will get back to everyone here when it's accomplished.
