Convert IFC to DWG
Convert IFC to DWG
christian.devol
Message 1 of 21
Convert IFC to DWG
christian.devol
How do I convert and IFC file to a DWG file in AutoCAD  Architecture 2020?
Replies (20)
Message 2 of 21
pendean
Community Legend
Community Legend
Message 3 of 21
christian.devol
When I go to the drop down and then open file the "Import IFC File and Create Drawing is not even an option".  Am I missing a step?
For example:
Message 4 of 21
dbroad
I don't think you can open an IFC file unless you have a drawing open. While inside a new blank drawing, use ifcimport.
If you love the ribbon, use the application menu while in a drawing and in the search bar, type ifc. Choose import. You must be in a drawing.
Architect, Registered NC, VA, SC, & GA.
Message 5 of 21
christian.devol
That was exactly what I needed to know.  Thank you so much.
Message 6 of 21
 even in a open tap doesn't work in my computer. Why?
Message 7 of 21
pendean
Community Legend
Community Legend
You are not running AutoCAD ARCHITECTURE, the topic of this forum, you simply have plain AutoCAD 2019.
Message 8 of 21
is not possible to import a .ifc drawing to autocad?
Message 9 of 21
pendean
Community Legend
Community Legend
Nope https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Import...
If you are on full subscription (not maintenance or legacy licensing), AutoCADARCH is free to you to install and use https://blogs.autodesk.com/autocad/introducing-autocad-2019-autocad-lt-2019/
Message 10 of 21
CJOkoMcC
Observer
Observer
Message 11 of 21
guido_maniglia
this option only appears if you have a drawing already open
Message 12 of 21
caaH5999
Community Visitor
Community Visitor
I'm running Autocad Architecture 2024.
I have a drawing open, still I cannot see the IFC import function. Also the program doesn't recognize the ifcimport-command.
Does anyone know if there's a plugin missing or something?
Message 13 of 21
pendean
Community Legend
Community Legend
@caaH5999 Which ACA2024 profile are you running there? Your RIBBON looks to be "as autocad", IFC import is not found there in any year version of ACA through 2024. you need to be running one of the ACA profiles instead
Message 14 of 21
DM2-fire
I'm a little puzzled.  I've running AutoCAD 2022 standard version.  In looking at the previous posts, it appears that my version can use the IFC Import Plugin (have I got that right?).
I when to options, and click on the PROFILES tab, I only had "<<Unnamed Profile>>", so I clicked "Add to List" and entered "AutoCAD".
If, while in a dwg file, I select "IMPORT" there is no IFC file type options to select.
What am I doing wrong?
Message 15 of 21
caaH5999
Community Visitor
Community Visitor
Thank you! This solves the issue 🙂
Message 16 of 21
pendean
Community Legend
Community Legend
@DM2-fire wrote:
...running AutoCAD 2022 standard version.  In looking at the previous posts, it appears that my version can use the IFC Import Plugin (have I got that right?).
No. The source of your information was inaccurate or the actual in-use software (or add-in) was missed.
Plain AutoCAD (which is not the software topic of this forum) does not have IFC import ability, never has: read all about it from Autodesk here https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Import-IFC-files-i...
Message 17 of 21
michaelHR9KR
I am adding this because I had trouble finding the IFC open option. I finally realized that this option is not available if I start "AutoCAD Architecture as AutoCAD" which I had done by mistake. The IFC option is not available even if I set the profile to AutoCAD Architecture. I needed to start the "AutoCAD Architecture". I believe this was hinted at but it was not clear enough for me to recognize.
Message 18 of 21
RvanTooren
Community Visitor
Community Visitor
I am working in autocad 2024 LT.
What are my options to import ifc in a dwg-drawing.
Or Convert ifc to dwg/dxf before importing.
Message 19 of 21
pendean
Community Legend
Community Legend
No option at all in any LT versions of AutoCAD. Sorry.
You'll need to find a 3rd party program or website for the conversion if the IFC creator is not able to get you a DXF or DWG.
Message 20 of 21
RvanTooren
Community Visitor
Community Visitor
Thank you. That's a clear answer.
Can you advise a such a program or website. It's for occasional use only.
