Content browser will not launch
sjkerbacher
Observer Observer
sjkerbacher
Observer
Observer
I am having issues inserting blocks from the content browser in Architecture 2017. I am able to insert most blocks but, blocks in the Special Construction/Detection and Alarm section will not insert. I receive the following message when trying to insert an Exit Sign(Wall);
"Duplicate definition of block I_ELEC_EXIT_WALL MOUNT_P ignored."
-FDC-
The block is already in the drawing.
Probably there is another block with the same name in the drawing.
Type "rename", rename the block  I_ELEC_EXIT_WALL MOUNT_P and try again.
Victoria.Studley
Hi @sjkerbacher,
I'm just checking in to see if you need more help with this. Did the suggestion that @-FDC- provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
