Are you using the out-of-the-box tools and source files? If so, are you willing to modify those?
The out-of-the-box Room Tag tool (based on US Imperial content) is set up to use the text style of the target drawing when a Room Tag is placed. That does not change the view block attribute font, however, and a use of the Update option of the MVBLOCK command will revert any selected room tags to the font/style used in the view block. But if you would rather not customize, just by setting your preferred text style current, you can get the room tags to use that text style.
If you do not want to rely on the end user to set the correct text style, you can set the tool up to use the text style as defined in the source file. In that case, you will need to edit the view block definition in the source file (the tool properties will tell you the file path and name) and then set the Attribute text style property of the tag tool to As defined by content, rather than Target drawing text style.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
