Change DXFOUT settings?
Is there any way to adjust the setting that DXFOUT uses so it does not bind xrefs or exlpode AEC objects? This is in references to ACA 2012.
Thank you,
Mike Lamka
Laks-Autodesk
I believe there is no settings to change the DXF output options you're looking for out-of-the-box in AutoCAD Architecture.
Lakshminarasimhan Seshadri
Thank you
