Can't save PDF as vector
I'm using AutoCAD 2018 on an iMac and I've previously been able to plot the drawing as a PDF using the DWG to PDF.pc3 "printer" and then open it in Illustrator and it's a vector file where I can individually grab each line. But now for some reason when I plot it this way, the image is a rastor image. It's driving me insane. I can't figure out what I'm doing wrong. Can anyone help?
Thank you!
Best,
Alex
rkmcswain
Do you have transparency enabled in this page setup? This will cause the entire output to be raster.
R.K. McSwain     | CADpanacea | on twitter
ChitownCADman
Post your .pdf file so we can take a look?
mekdem.kidane
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @rkmcswain provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
senarvi
Observer
Observer
Some visual styles also cause the output to be raster. Try changing the view to 2D Wireframe.
