Bringing the Rev Triangle forward
I want the rev triangle to stand out on top of lines (example: in a schedule where there are lines closer together then the size of triangle).
I tried bring it forward, and I don't want to trim the lines either so when i have to remove the triangle at a later date.
gotphish001
Put a wipeout around the revision triangle. On the Home tab in teh annotation section if you pull down the drop down window for the revision symbol there are wipeout tools. You have to put a wipeout around the triangle then put the triangle infront of the wipeout but leave the other linework behind it.
You can also just add the wipeout to your triangle revision block so it just does it automatically.
Nick DiPietro
Cad Manager/Monkey
