Architecture not showing all objects in section view.
I am a novice at Architecture. In the section I do not see all the objects. Some objects look like they might be turned off because it looks like they are hiding objects but not showing up. I tried Level of detail and changing the 2d elevation\section style and cannot get the items to show.
Matt
David_W_Koch
Can you share a file (or files, if your 2D Section/Elevation is in a separate file from the original objects)?  Noting what release of AutoCAD Architecture ou are using and which objects are not showing up will help us help you, also.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
