Are you using ACA?? You are trying to use a shovel as a screwdriver!
What suggestions are you after. Mine would be your method is crazy
especially if you have ACA.
If you only have autocad then there is probably still better ways to do it.
wrote in message news:5587206@discussion.autodesk.com...
See attached. This will be my first 3d house. After I create the floor plan
I will region it into 3d.
Plan then to boolean places for windows. Any suggestions would be welcomed.
