Automatically closing Drawing1
calfcreek_2
627 次查看
3 条回复
1 条消息(共 4 条)
calfcreek_2
I'm sorry this is a bit of a repeat but I can't find the answer I need in all of the threads.
I guess I'm one of the few who actually likes Drawing1. I want it to remain open even after I open another drawing.
Our latest setup with ACA 19 has come with the auto-close behavior and I can't seem to get it to stop.
Startup = 0
Qnew = our template file (similar) to previous versions other than file format.
Demand load ObjectARX apps: = Object detect and command invoke
FileDia = 1
Thanks for any support.
Keith D. Rodebush
RA
0 个赞
628 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
pendean
Community Legend
Community Legend
Change something in the file and it will not auto close: you probably had a startup in your old setup that changed a variable or two automatically in any file that opened.
0 个赞
3 条消息(共 4 条)
leothebuilder
Check your SDI setting?
0 Multiple drawing interface enabled
1 Multiple drawing interface disabled
2 Multiple drawing interface disabled by an application that does not support multiple drawings
3 Multiple drawing interface disabled by user and by an application that does not support multiple drawings.
0 个赞
4 条消息(共 4 条)
David_W_Koch
I usually do a ZOOM Extents in Drawing1 to assure that it will not close when I open another file.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
0 个赞
