autoCAD walls, doors, windows are not understood in 3dsMax
Maricia
Maricia
When I import drawing from AutoCAD Architecture 2019 to 3ds Max Design 2015, no walls and windows appear. How can I solve this, since I wanted to edit and render in 3ds Max Design? Thank you.
Only a guess but suspect the older Max can not read the AEC Objects from the newer AutoCAD Architecture. Do you have access to the new Max?
Maricia
Yes, I just upgraded for a 3dsMax newer version because I thought it was the problem.
Thank you for answering 😉
