Global Cut Plane
Global Cut Plane
Despite the size of the range for global cut plane some objects (e.g. windows) are not displayed.
More specifically, despite the size of the range for the cut plane, the only objects that are displayed are those through which the "Cut Height" traverses....  It is as if the fields "Display Above Range" and "Display Below Range" have no effect.
Please advise
Roger
I
dbroad
Global cut plane is not a range but a single elevation.  The view range is a secondary limit.  Window display, other than at the cut plane, however, depends on default, style, and object overrides and may be affected by a wall's cut plane height.  Look at the plan display components for a window style, particularly the ones above and below the cut plane.  If they are off, the view range doesn't apply.
Architect, Registered NC, VA, SC, & GA.
brian_adams
let my add a bit. I is very important is it checked or not "do true cut" in display properties of aec element
Victoria.Studley
Hi @Anonymous,
It looks like both @dbroad and @brian_adams provided some information to help you. Did their posts help you with this issue?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
