AutoCAD Architecture - Troubleshooting: Split Wall
BDEZINE
BDEZINE
Hi, I have walls that are split in a few location, can you help me solve this issue. Thanks!
[ The subject line of this post has been edited to include the product name by @handjonathan ]
faugustom
Do you have any clipped xref in the same file? Maybe it's ghost walls
David_W_Koch
In addition to @faugustom 's excellent suggestion regarding clipped external references, another possible item causing the gaps may be Walls on a layer that is frozen or turned off.  Freezing a layer does not prevent Wall cleanup (nor does clipping an external reference).  One common scenario is if you have existing-to-be-removed (demolition) Walls in the same file as existing-to-remain and new construction Walls.  Freezing the demolition Wall layer will not stop them from trying to clean up with any other Walls that cross them.  Use different Wall Cleanup Groups for existing-to-remain, existing-to-be-removed and new work Walls.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
BDEZINE
Correct, it is a ghost wall! I'm surprised that it shows up when the xref is frozen!
