Is there any method to create Project Levels for each different Project Division?
I mean:
Project-Division A each level = 3 meters
Project-Division B each level = 2.7 meters
etc.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Solved by faugustom. Go to Solution.
Solved by David_W_Koch. Go to Solution.
So far as I know, there is not a way to have Division-specific Levels. You can, of course, only create Constructs for specific combinations of Level and Division.
So if you had Division A and Division B, and Levels:
4 [elevation 6000]
3 [elevation 5400]
2 [elevation 3000]
1 [elevation 2700]
0 [elevation 0]
You could have Constructs for A & 0, B & 0, A & 1, B & 2, A & 3 and B & 5.
If having non-consecutive Level names in a division is not to you liking, you could name them:
B2 [elevation 6000]
A2 [elevation 5400]
B1 [elevation 3000]
A1 [elevation 2700]
0 [elevation 0]
If I am incorrect about my initial statement, I am sure someone will chime in and point out the error.
a bit tricky but works.
Is there any method to create levels and divisions with CSV file or similar? (maybe lisp)
I hope a day Autodesk can update this feature. No matter how good is Revit, definitely ACA have many potential.
