Auto text formating
Auto text formating
Auto text formating
Using Autocad Architecture 2021 with Windows 10. Text re-formating occurs when switching between paper space and model space. How can I stop that
dbroad
Be specific about what type of reformatting is occurring (height, width factor, font, obliquing angle, bold, visibility, etc.)  Other than height, I've never seen 'reformatting' happen.
Architect, Registered NC, VA, SC, & GA.
The formatting that occurs is not obvious so I can't be anymore specific. It's really more of an annoyance than a problem. However it occurs when changing from model to paper space and sometimes from PS sheet to  sheet without noticeable changes. I get a message (reformatting text) at the lower right just above the status bar that pauses everything for 10 to 15 seconds. Thanks for your review.
pendean
Community Legend
Community Legend
>>>...m. However it occurs when changing from model to paper space and sometimes from PS sheet to sheet without noticeable changes. I get a message (reformatting text) at the lower right just above the status bar ...<<<
Read this similar issue https://forums.autodesk.com/t5/autocad-lt-forum/autocad-lt-2020-message-quot-please-wait-formatting-...
The other thing to try is to fix your STYLE settings for missing fonts, and remove font overrides in all of your MTEXT.
This is, as they say, a user error/omission in the file(s) you use.
Thanks, I'll try the suggestions. Please consider this problem solved.
