AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Arrived today - BIG DEAL
45 REPLIES 45
Message 1 of 46
754 Views, 45 Replies
So far, I've loaded it, opened it, played with for an hour or two and guess what I'm not impressed with this great new upgrade yet . . . . Another change in format, I read in the first README after installation of a migration of my old projects to new ones using BATCH files and scripts - HOW MSDOS !!!!!
So far I have not seen many big enhancements AND I tried to find VIZ Render - WHERE IS IT ??? Don't tell me I now have to go and purchase Viz or Max because they dropped it. If so - thats not an upgrade.
I may not have looked too deep yet but it's like buying a new car - where's the WOW factor . . . . I'm getting bored of Autodsk and the $1000 per year subscription for token upgrades. . . . . Any body agree
45 REPLIES 45
Message 21 of 46
Improved rendering ??? They dropped Viz Render haven't they ????
Message 22 of 46
Yes they dropped viz render in 2008. It was a pile of cr*p in 2007 as i think they knew it had a limited life and associated development time appropriately.
The internal rendering engine within acad (and ACA) produce really good results and supports RPCs. When I first learned of the demise of viz render I was annoyed as well, but the quality I'm achieving directly from ACA is actually better than viz render. Having said that, the full Viz is better again because it uses the mental ray engine (same one ACA is now using). Viz render was using the older radiosity engine, which was OK for its time. Give it a try, you may be pleasantly surprised.
Message 23 of 46
yes, use of the old VISRETAIN variable...
Message 24 of 46
Craig,
First, let me apologize for yesterdays post. It was not a good day and you
received my vent.
You have one up on me; I started with AutoCAD 2.5. The reference to
programming is really about the time it takes for the development of a
program. I think we can all agree that ACA is NOT a simple little program.
It is absolutely amazing what these vertical market products can do! CAD
has become the byproduct of a virtual model that is visually awesome. I
have done enough programming that it is truly overwhelming to me to image
the effort that must go into creating these very complex drawing objects.
In my personal opinion, I just think we get a little blinded by the WOW of
what the program does for us compared to what is used to do, and we start
thinking that if it can do THIS it SHOULD be able to THAT; but we forget
what has to be done the make THAT happen. I may be being extremely
optimistic and giving Autodesk to much credit, but I think the programmers
are working on making the things we WANT available; it just takes more time
than we think it should.
And for the whole Revit issue, I really don't want to go there! I don't
know whether you have used Revit or not: IT IS NOT BASED ON AutoCAD!
EVERYTHING you know about drawing, every workflow you have, every process
you use; throw them all out the window and start over! AND if you can't
model it, you can't draw it! If you think you are frustrated with what ACA
can't model yet, just go play with Revit. At least we can draw what we
can't model!
In my opinion, the biggest problem with the timeframe of new developments in
AEC objects is that there are still to many people using plain AutoCAD (or
worse AutoCAD LT) to do drafting instead of the advanced modeling WE have
come to expect! The AutoCAD programmers have all these DRAFTERS that want
drawing to get easier, but those users won't figure it out that modeling is
what makes it easier and we need their programming resources to make it even
easier!
My rapidiograph set is safely on the shelf next to the Leroy set,
planimeter, and binders of templates (who remembers they used to be made out
of plastic instead of bits?).
Have a good day.
Larry Bettes
ADT, C3D & LDT/CD
(all 2007 with all SPs installed)
P4 - Dual Core 3.0 GHz, 3.00 GB RAM
nVidia GeForce 6800 GS AGP - 256 MB
Windows XP Pro, SP 2
wrote in message news:5542311@discussion.autodesk.com...
Well Larry - yes , I do program. This stems from when I used Autocad 2.16
and the only way to get the thing to work properly was to customise using
LISP, BASIC, DOS Batch files, hacks, work arounds, etc. Those were he days
the only thing it could do was line, text, circle and dimensions. I
therefore have had a LITLLE experience with the software. We also used
drawing boards, pens and slide rules.
And yes- ME ME ME ME. I am the customer to Adesk. If I treated my clients
with the same carrots as my clients they would go elsewhere. The customer is
always right and the continung attitude of Adesk just flicking crumbs to
crowd because they have market share is pathetic.
Then came Revit - a real competitor and threat so they bought it and nobled
it. I suspect the same track will happen to its development.
The major upgrade is too slow for the money we pay for it. Its about time
they made a concerted effort to fix the current and develope it up properly
instead of making more GUI improvments. No point if the elements do grow
with the technology.
Where's my 0.25m rapidgraph - who knows what that is ??? Better stil -
velium drawing line. . .
Message 25 of 46
someone, somewhere is saying "i knew he couldn't be quiet on this one!:)
"And for the whole Revit issue, I really don't want to go there!"
but you did:)
"if you can't model it, you can't draw it!"
in Revit this perception is not true. detailing is easier now since Revit 9
than in AutoCAD/ADT 2007 (fewer clicks and better more stable tools) can't
wait for 08!
"At least we can draw what we can't model!"
again a common perception - where the miss comes in is: In Revit Everything
is Sooo much Easier to model than ADT.
"still to many people using plain AutoCAD (or worse AutoCAD LT)"
or better yet using ACA/ADT as AutoCAD. Can Anyone tell us what percentage
of the .5 million seats of ACA/ADT are being used this way?
what is true is that in Revit its not as easy to "fake" it - but when you
know it, you don't have to fake it.
still don't have ACA... maybe fate?
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
"Larry Bettes" wrote in message
news:5543000@discussion.autodesk.com...
Craig,
received my vent.
can't model!
easier!
Have a good day.
Larry Bettes
ADT, C3D & LDT/CD
Message 26 of 46
They put mental ray inside of AutoCAD. I would say that is improved.
wrote in message news:5542312@discussion.autodesk.com...
Message 27 of 46
of plastic instead of bits?).<<
Oh Yea!!????
Well, I've got all you losers beat hands down!!!!
Rudy Beuc AIA
R. Beuc Architects
Craig,
received my vent.
can't model!
easier!
Have a good day.
Larry Bettes
ADT, C3D & LDT/CD
Message 28 of 46
Pencils anyone?
Message 29 of 46
Great pics Rudy. Thanks for posting them. Requisitioning officer wanted to make sure
there were no shortages right?
"Rudy Beuc" wrote in message
news:5543385@discussion.autodesk.com...
Pencils anyone?
Message 30 of 46
Actually I've inherited it all.
Rudy Beuc Sr. was an architect too. Right before the WWII he was worried all
of the good German pencils would be impossiable to get. So he stocked up.
My Father's been in private practice since 61 and we still have all of that
accumulated stuff.
I was able to get rid of the 286 and 486. I acquired those and was able to
shed them with a minimum amount of grief.
Rudy Beuc III
R. Beuc Architects
Mabey I should post a house plan from Sr......
"Doug Broad" wrote in message
news:5543423@discussion.autodesk.com...
make sure
Pencils anyone?
Message 31 of 46
Sounds like a nice history. My father was a pilot (like Mark Twain). I'm an architect.
My son is likely to become an aerospace engineer. So much for passing skills from father
to son. 😉
news:5543437@discussion.autodesk.com...
accumulated stuff.
Rudy Beuc III
R. Beuc Architects
make sure
Pencils anyone?
Message 32 of 46
Slow week......
Message 33 of 46
news:5543382@discussion.autodesk.com...
Oh Yea!!????
Rudy Beuc AIA
R. Beuc Architects
Craig,
received my v
ent.
awing objects.
And for the whole
can't model!
pments in
easier!
Have a good day.
Larry Bettes
ADT, C3D & LDT/CD
Message 34 of 46
I think it was rapidograph and vellum.
Better still how about ink bow pens and ammonia tubes!
Message 35 of 46
I have a couple of transits about that same style I would sell you if you
want to increase your stock:-)
JerryL
news:5543507@discussion.autodesk.com...
Slow week......
Message 36 of 46
What fabulous heirlooms for a family tradition in architecture. If it is a slow week might I suggest you design a bookcase/cabinet to hold and display your treasures? In years to come your descendants will say "Oh yes that cabinet was designed by my ..... and guess what, he used some antiquated system called ACA 2008 to make his unique design -amazing what they could do back then with such limited tools but he was very clever and resourceful!"
Happy Easter
(Perhaps an ovoid design to reflect the occasion)
TerryT
Message 37 of 46
Actually AutoCAD will resolve the xref dependant layers to the layer state
in its native drawing, not an intermediate drawing. In other words, when
xrefing a View into a Sheet, the View layer settings are ignored, while the
Construct (i.e. native drawing) are used. So 2008 adds new functionality to
ensure that a View drives the Sheet's layer settings during initial creation
and when its xrefs are reloaded.
Chris
Chris Yanchar
Product Design Manager
AutoCAD Design & DWF Apps
AEC
Autodesk, Inc.
wrote in message news:5542335@discussion.autodesk.com...
Message 38 of 46
wooo nice post I think I can cry here in the middle of all of you long time architects who know ACAD since v 2.x an then all its desktops and then all their renamings.
*Happy face here*
I'm studying Architecture in Mexico. This is my last Month. For the final project teachers are requesting an executive project by each student. That is hard. Using just Autocad, it takes a long time doing just the architectural, finishes, windows & doors. Not to speak structure and MEP. Then the details. Then 3d model, texture, lighning, render to get stills and animations.
So, out there in the market exists some software which, from a 3d model, can draw the plans: ArchiCAD, ADT 2008, Revit. So I tought: Why not spend the time it takes from drawing sections into learning ADT? After all, I'm REALLY GOOD using Autocad alone.
Then I got a trial for ADT 2007. Then, soon later came out Autocad Architecture and I requested the trial, and began using it.
Wow. Walls are drawn just like lines. Pretty!
Wait a second ... Walls create some layers i'm not used with. These layers came with weird plot styles. Ok ok I'm sure this is all customizable...
-2 days later-
God ... I got the walls to be drawn the way I Want. Pretty!
Now I need this RAMP...
-Several days later...-
http://discussion.autodesk.com/thread.jspa?threadID=567588
Drew slabs as ramps
*face looks tired*
GOD!!!! These walls do not cleanup like I want them to cleanup!...
These slabs do not display properly, they look good as 3D but not in plan...
Took the ramp object from catalog and spent a whole day trying to get the slope I wanted.
Straight ramps then became easy.
Try to draw an S shaped ramp...
*angry face*
WHY ARE STAIRS SO HARD TO DISPLAY PROPERLY????
Tried once and again editing object display...
Well it could be GREAT if the "edit object display" worked like the edit interface display window where you just click the piece you want to edit ...
*Start crying*
how can I adjust my walls to the roof? Is not there an automated way? Say, like the roof slab trims the walls?
Why my stair does not make a hole in the roof? Archicad does it! I've saw people doing it!
Why is not the help system as friendly as Autocad's? whoooo I miss the "Concept / procedure / quick reference" layout ...
*Curious face*
Hm.
There are slabs and roof slabs ... what could the difference be?
*angry again*
DXMN YOU F***ING project navigator I dont know what you want!!!! I DON'T KNOW WHAT YOU DO!!!!!!!!!!!!!!!!!!!!!!!!!!
DAAAAAAAAAAAAAAAAAAAAAAAAAAAA Why are slabs below 0.00 not displaying???
*Crying again*
Whoooooooooo i punched my cat so hard in my anger... poor kitty ... But this is (*angry face here*) All this DAMNED-WALL-NOT CLEANING-UP PROPERLY'S FAULT YOU KEYBOARD WITH A HARD SPACEBAR KRAAAAAAAAAAAAAAAG
-A keyboard & mouse later-
Life is not as hard. I can still live by selling piracy. Or I can sell my body to science. I can even wash cars!
-Few reading posts later-
So they say Mental Ray is now available in Autocad? Nice! Can it produce particle systems like 3dsmax do?
This forum has been a blessing ... But there are so many things and workarounds that i'm thiking of abandoning Autocad Architecture and leave autocad alone.
Yeah I know there is a learning curve for any software but GOD!
ADT is so hard ...
I'll be posting more questions ...
Message 39 of 46
To this I will only say:
One cannot expect to come into a program with the immense capabilities of ACA 2008 green, and in a week or two become proficient. It is a life long pursuit just as the profession of achitecture is. The program can draw easy 2-d or complicated complete 3-d models with imbedded information that can be extracted for a multitude of purposes....and all points in between. To try to vault to the complete 3-d model capabilities without a firm knowledge of the base program is...well silly.
Now I will grant you that most Architecture schools do a very poor job of Acad training. In my case we were generally thrown in the water and told to swim. I spent 100's of hours of my own time learning ACAD. You will have to do the same. BTW - one who REALLY knows Acad has a leg up on his classmates when it comes time to be hired as an intern.
Good luck in your future pursuits...
Keith D. Rodebush
SGAI
Message 40 of 46
To figure ADT out by yourself is a big ask. When you first learnt acad did you attend any training courses? You will find the 3 day training course for ADT will give you a big start-up help. Sure there are lots of things in it that drive us nuts, but you just use a work-around like any other software.
If you're finding it difficult, get some help.
