Array command stopped workng
I was creating arrays and suddenly in one of my drawings the command stopped working.  It would show the original objects and the grips for spacing and quantity but when I tried changing them (the spacing and quantity) only the orignal objects showed.  I copied a working array from another drawing into the one that quit working.  The quantity and spacing grips still showed up but the objects wouldn't move.  I also noticed that it was calling the object it created a block instead of an array.  Is this an anomolly or a know problem.
it first happened when I changed the scale of a block that I was trying to array.  The source item I selected (the original location) disappeared after saving changes to the array and nothing seemed to work after that (using array)  I purged and audited the drawing to no avail.  anything I am over looking?
David
UPDATE:
I wblocked the entire drawing and that fixed the problem.  Must have been a gremlin.
Matthew.Alder
This has happened to me a number of times, very annoying.
Would like a fix soon.
