- Mute
- Permalink
- Report
I was creating arrays and suddenly in one of my drawings the command stopped working. It would show the original objects and the grips for spacing and quantity but when I tried changing them (the spacing and quantity) only the orignal objects showed. I copied a working array from another drawing into the one that quit working. The quantity and spacing grips still showed up but the objects wouldn't move. I also noticed that it was calling the object it created a block instead of an array. Is this an anomolly or a know problem.
it first happened when I changed the scale of a block that I was trying to array. The source item I selected (the original location) disappeared after saving changes to the array and nothing seemed to work after that (using array) I purged and audited the drawing to no avail. anything I am over looking?
David
