Array and arrayclassic commands have disappeared
Hello All:
Windows 7 Pro x64,
AutoCAD LT 2013
Working on a house drawing today and the array commands have disappeared.
Check this out:
Command: array
Command: ARRAYCLAssic
Unknown command "ARRAYCLASSIC". Press F1 for help.
The array command did nothing, and you can see the response form arrayclassic.
I have just closed the drawing I was on and opened and entirely new one I was working on last week and again, the array commands are gone.
Deoes anyone know how you fix this?
Cheers,
john
leothebuilder
This is the Autocad Architecture forum, not the Autocad LT forum.
Is it only the ARRAY command that does not work?
Do all other commands work properly?
Have you tried ARRAYPOLAR command?
Did these commands work properly previously or is this a new install?
Hi All:
My AutocadLT is running on a VM which I had a backup to so I went to the backup and it works fine again.
I can trace my problem to try to get a program call "Tralain" running on my machine last week. its an old WindowsXP 32 piece of SW that could convert DWG files in long and lats to UTM coordinates. I was unsuccessful in getting it to run on Windows 7 but the installing and uninstalling likley borked my AcaD. Even after running repari, autodad just would not run properly.
In any case, I'm back up on the backup so I am good.
Sorry for the wrong forum.
Cheers,
John
