Apologies as I'm not a lisp programmer and hoping anyone is able to help, I've been using the align lsp below for some time now and find it quite useful. I would however appreciate it if someone could assist in have the lsp answer "yes" to the scale option as opposed to what it's currently doing to simply automatically answer "no" and then simply align the object without having to choose the option. It does make life a little easier.
(DEFUN C:GN(/ gp)(setq gp (ssget))(COMMAND "align" gp "" (setq P1 (getpoint "\nSpecify 1st source point:"))
(setq P2 (getpoint "\nSpecify 1st destination point:"))
(setq P3 (getpoint "\nSpecify 2nd source point:"))
(setq P4 (getpoint "\nSpecify 2nd destination point:"))""""))
Any help is appreciated.
Ashley
Solved by massimo.corradi. Go to Solution.
Hello Ashley,
that would be here:
(setq P4 (getpoint "\nSpecify 2nd destination point:"))"" "Yes"))
Awesome! Massimo.Corradi,
I was actually looking into the lsp programming and was playing around with the Yes input i realize also that the "" means enter and I was missing that part. Thanks so much, much appreciated, works like a charm!
