Add Comment to Construct
Can I add  comments and notes to my construct version when I check them in and out from the project navigator. It seems like a nice feature but can not seem to fine how to add the notations.
ACA2015
Todd
Keith.Brown
When you check the file back in you have the ability to add a comment.  If you want to add a a comment after the fact you can edit the xml file that is the same name as the dwg and in the same directory.
I do not get the same window pop up at check in time? using ACA 2015
Now that I know that it's not me but a program error can someone at Autodesk Please contact me to correct this issue.
I do have ACA2016 installed out of the box and have tried it as well, same results, it does not allow me to add comments at check in time.This has always seemed like a very handy tool that I would like to utilize please advise me on how to fix the problem Autodesk.
Todd
Keith.Brown
Can you check this setting in the Project Properties?  I opened the dialog by going into the project browser and right clicking on the project and selecting properties.
Victoria.Studley
Hi @Anonymous,
Thank you for posting your question here. Hopefully we can help you enable the comments on your project - it is a handy tool.
In the same train of thought as @Keith.Brown, it does seem like the comments feature might be turned off in your project. Could you please verify that they are turned on?
Here is an article that explains where you can find this setting in your project as well.
Please let me know if this helps you enable the comments, or if you need more help.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
That was it. Not sure why Auto Desk would have it off by default?
Todd
