ACA 2018 Dynamic Input Prompt does not refresh from last input
kenn
Message 1 of 37
kenn
I have a Dynamic Input prompt issue that just started a week ago.  I have noticed that the Dynamic Input box that follows my cursor no longer clears itself of the last data input or last data point. See the attached screen shot.  It does this for all of my drawings except our QNEW drawing template.
My Computer Info:
HP Z420
Intel Xeon CPU E5-1620v2 @ 3.70GHz
GB RAM
NVIDIA Quadro K2000
Windows 7 Pro
Any ideas or suggestions on how to resolve this sudden Dynamic Input prompt quirk would be greatly appreciated.
Replies (36)
Message 21 of 37
kenn
The cursor location coordinates are turned off and do not display.  The Dynamic Input box retains input from lets sat 5 or 6 commands ago and does not clear itself like it is supposed to.  It just continues to retain old data input and remains visible all of the time.
Message 22 of 37
pendean
Community Legend
Community Legend
Search these forums this appears to be a very random problem that no one has an answer to: since most of us here cannot replicate, I guess it is still so.
But since it appears to be office-wide for you based on your statements, can you confirm if you are running any add-ons in ACA2018? If yes, what are they?
Are you logged into Windows with a very limited user account? If yes, does the problem go away if you log in with a local admin account? Your IT may have to help you with that one.
Another random thought: Start GRAPHICSCONFIG command and turn off hardware acceleration: does the issue go away?
Message 23 of 37
kenn
I tried all of your ideas and unfortunately none of them worked.  I appreciate the input.  I am a local admin on my computer and I also tried using my IT Admin account (I am also the onsite IT Manager / First Responder) and there was no change in the Dynamic Input box problem.  The only thing that works is unchecking the Enable Pointer Input box under the Dynamic Input settings but that defeats the purposing of Dynamic Input.
I may have to live with this as I am the only one on the design staff that uses Dynamic Input.
Message 24 of 37
Victoria.Studley
Hi @kenn,
Thanks for the Screencast. I tried to replicate this, and I also haven't been able to, even with the additional video of what's happening precisely. It does seem rather odd that it's happening on all machines in your office, and not just one.
  • Is there anything else in common between the machines that you can think of?
  • Particular antivirus or security programs? Registry cleaner?
  • Could it be the pointing device and/or its driver version? Maybe try a different mouse make/model and see if it persists.
I'm sorry it's come down to this - we've certainly exhausted most, if not all, of the troubleshooting options I can think of that might affect this.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 25 of 37
Victoria.Studley
Hi @kenn,
Have you had a chance to look into the other questions I posed yesterday? Did they help you narrow down the cause of the issue?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Message 26 of 37
kenn
Hi @Victoria.Studley
I tried your suggestions yesterday and tried a different manufacturer of mouse and no change.  Our anti-virus program is Webroot which we have had in place for about 2 years. I do not have any registry cleaners installed.
I did checked my Programs and Features in Control Panel and the only program that was installed about the time when this problem started was Adobe Flash Player 27 ActiveX ver 27.0.0.130
Ken
Message 27 of 37
kenn
I just stumbled on to a pattern.  I started a new drawing and my first command _dimlinear (selecting it from the Ribbon) and the Dynamic Input issues started immediately.  I then started another new drawing and drew several lines with no problem.  As soon as I did _dimlinear, the problem started.
Ken
Message 28 of 37
Victoria.Studley
Hi @kenn,
Thanks for the update. I have the very same version of Adobe Flash Player 27 ActiveX on both of my machines here, and still can't reproduce the issue. Any Windows Updates around the time the issue started happening?
Another customer is reporting pretty much the same issue over in this thread, so it's not just you who's experiencing this.
Could you create a system information file (NFO) for the affected machine, and either attach it to your reply post or send it to me in a PM?
I'd like to compare your system to a working one to see if I might spot any differences.
Victoria Studley
Message 29 of 37
kenn
Attached is the system info file.   There were no Windows updates that were installed when the problem started.  The last Windows update was 5/20/17
Ken
Message 30 of 37
Victoria.Studley
Hi @kenn,
Thank you for sending that over.
It looks like you don't have the certified driver version installed for AutoCAD 2018 products on Windows 7. Could you please install the certified driver version and let me know if the issue subsides?
Your Card: NVIDIA Quadro K2000
Your current driver version: 9.18.13.3250
Certified driver version: 21.21.13.7586 (download it here)
Victoria Studley
Message 31 of 37
kenn
Hi @Victoria.Studley,
I updated my NVIDIA driver to version 21.21.13.7586 and there was no change.
I also ran the AutoCAD Architecture 2018.0.3 update that came out earlier today and there was no change with update as well.
Ken
Message 32 of 37
Victoria.Studley
Hi @kenn,
I'm sorry to hear installing the certified driver version and the new updated for ACA 2018 didn't help.
The only other possible conflict I see is that there are a lot of third-party modeling/rendering applications installed on the machine (Sketchup, V-Ray for Sketchup, Kerkythea, Rhino, , etc.).
Another troubleshooting option here is to try a diagnostic startup to test ACA 2018 in a clean environment to eliminate these other variables. Could you try this and let us know what happens?
Victoria Studley
Message 33 of 37
kenn
I have been doing a lot of testing today.  I finally received my first computer back from our IT support service as they had to rebuild the computer and re-install the Windows 7 Pro operating system.  I re-installed ACA 2018 through our typical network deployment method.
I launched ACA 2018 without the recent update ACA 2018.1.1 and my Dynamic Input problem was gone.
I then ran the ACA 2018.1.1 update and  launched ACA 2018.  My first command was _dimlinear and my Dynamic Input problem came back.
As a 3rd test, I uninstalled the ACA 2018.1.1 update, restarted my computer and then launched ACA 2018 and Dynamic Input problem was gone.  Hence, the problem must be in the ACA 2018.1.1 update.
I ran (2) System Information reports.  One is pre ACA 2018.1.1 update and the other is post ACA 2018.1.1 update.  Both reports are in the attached zip file.
Hopefully this sheds some light on my Dynamic Input mystery.
Ken
Message 34 of 37
I was having the same dynamic input visibility problem as described by Kenn. I've uninstalled the ACA 2018.1.1 update, and now my input works like a charm (visually just as it did prior to the update). Thanks for all the trouble shooting. Hopefully a fix can be found for the update. Thanks again.
Ken Nanna
Dell Precision 7510
Intel Core i7-6920HQ CPU @ 2.90GHz
32 GB RAM
NVIDIA Quadro M2000
Windows 7 Enterprise
Message 35 of 37
Victoria.Studley
Hi @kenn,
Thank you for the additional updates. Although I still haven't been able to reproduce this here on my system, I've logged the issue with the development team, so that they are aware that there may be an issue with the 2018.1.1 update and dynamic input.
Victoria Studley
Message 36 of 37
I have the same dynamic input problem.  As long as dynamic is turned on, the display is always showing something from the last command or hovering over objects.  Too annoying to be productive and it showed up an updated to 2018 autocad.
Message 37 of 37
giancarlodaleffe
the previous autocad update 2018.1 did not give these problems. you can get it online again ..
look this tread . https://forums.autodesk.com/t5/autocad-architecture-forum/2018-1-1-input-dinamico/m-p/7783706#M63589 for image.
