ACA 2015: Model building in single construct and separate levels using views?
arkitek2ss
arkitek2ss
Is there a way to model a bldg in a single construct and then create the different levels using the views (similar to revit)?
@arkitek2ss for clarity VStudley edited the original subject: 2015: modeling
pendean
Community Legend
Community Legend
>>>>..Is there a way to model a bldg in a single construct ...<<<
Sure you can, always could: but unlike REVIT with a server based model, yours will be fully loaded on your PC and AutoCAD's performance may slow down if your system is not ideal.
>>>... then create the different levels ...<<<
Lots of reading and training material in HELP and online
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
https://knowledge.autodesk.com/support/autocad-architecture/getting-started/caas/CloudHelp/cloudhelp...
Overview https://knowledge.autodesk.com/support/autocad-architecture/getting-started/caas/CloudHelp/cloudhelp...
Victoria.Studley
Hi @arkitek2ss,
I'm just checking in to see if you need more help with this. Did the information that @pendean provided help answer your question and point you in the right direction?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
