About AutoCAD Architecture templates and their use
Shay.Gaghe
Shay.Gaghe
hi
i wonder what template is used for what tasks?
@Shay.Gaghe for clarity VStudley embedded your image directly in this post and edited the original subject: about templates and thier use
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
brian_adams
Well all the templates "METRIC" or "GLOBAL" it is unit system
Stb. or Ctb. is plot style table
"Model" it is for modeling preferably
"Sheet" for drawings arrangement- in AEC project
"Structural" for modeling bearing structers
GSM...well never used it
"elevetions" for creating sections in Views-in AEC project
"detail and kaynote" for sections an elevations
"autocad template" for ordinary AutoCAD
THE FIRST OF ALL YOU NEED TO START WITH A SOME model TAMPLATE....than else
Victoria.Studley
Hi @Shay.Gaghe,
In addition to @brian_adams's explanation, I can provide following information and resources about the AutoCAD Architecture drawing and project templates:
  • About Templates
  • About Template Projects
  • Aec Model templates: come with standard AEC Object Styles in them, as well as standard Display Configurations to help you display those AEC objects.
  • Imperial vs. Metric vs. Global: these templates are set up with units and styles in specific measurement systems.
  • CTB vs. STB: these are set up with plot style tables that either use color (CTB) or style (STB) to determine how your objects will plot.
  • GSA templates: contain styles and standards that adhere to GSA guidelines.
  • Structural templates: contain styles and standards for structural design.
  • Project templates: set up an entire project to adhere to certain styles and standards.
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Shay.Gaghe,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
