2D sections through Point Clouds
Good afternoon,
I’m trying to cut a 2D section in AutoCAD Architecture 2017 through a point cloud and solid modeled components. I used to be able to do this by using the section tool inside the tool pallet under the Annotation tab. When I use this I get everything but the point cloud information. Can anyone tell me what happened to this command or how we are supposed to accomplish this now? I have attached some screen shots of what I'm talking about hoping it will help build a visual.
Thanks in advance
Victoria.Studley
Hi @Anonymous,
Thank you for posting your question here in the community. Are you trying to cut a live section through both AEC objects and 3D solids, in addition to the point cloud?
The Building Section tool you're using (from the tool palette in ACA) only works on AEC objects for live sectioning, and you need to use the SECTIONPLANE command to get a live section through a point cloud. Here is an article that explains the process of using both tools together.
If you're trying to generate 2D geometry from a point cloud, you may find these resources helpful as well:
PCEXTRACTSECTION (Command)
Inferring Geometry From Point Clouds
Cropping Point Clouds
Working With Point Clouds
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
