2d Elevation line work question
tevansERD
tevansERD
Our 3d cabinet blocks have a door swing indicator on them. When we generate the 2d elevation of them all of the linework is red and continuous. I would like to maybe change the color and we need the door swing line to be hidden.
I have attached and example of the 3d block front view and the 2d elevation. Where is the linework controlled? is this controlled with a display rep or somewhere else?
Thank you in advance for your assistance
R_Tweed
I don't know if your using multi-view blocks but I think the display settings your looking for are in the 2d section/ elevation style. I've attached a sample dwg that I hope will be helpful. I'm doing several things in this drawing. The upper cabinets use a 2d elevation for the swing that does not display in model and the lower casework is using the model view block to extract the swing lines.  My faucet block is just a general block and the hood is a solid, that I've made to see the effect on general items. This dwg is pulled from my test or sandbox model.  I mention that because there are several options being used between the uppers and the base cabs.  Some blocks have been adjusted using scales, etc.
