Message 1 of 16
So what happened to the block editor tab on top in 2018? Even if you right click on a block and say edit in place there isn't a tab at the top of the screen. You can no longer test a block while in the block editor and to get out of the command you can't have anything selected and you must right click to save your changes. In the edit block in place you can no longer add/remove anything to the working set either. Is this a bug or is this how it's going to be from now on?
Steve
