Civil 3d 2012 ...make a c3d table use a smaller area of my map?
caddie99
Message 1 of 10
caddie99
I Use Civil 3d 2012 windows 7 64
How can I make a civil 3d table
That is have less space above
and below the text in each row,
so the printed table takes up less
room on the map. My Table Fonts are
all ready as small as possible.
Replies (9)
Message 2 of 10
Victoria.Studley
Hi @caddie99!
Welcome and thank you for posting. I'm reaching out to one of our Civil 3D specialists to help answer this question thoroughly. Could you post a small sample file so that we can better understand what you're trying to accomplish?
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 3 of 10
caddie99
SAMPLE AS REQUESTED
BEFORE
AFTER (EXPLODING BEFORE TABLE AND MANUALLY MOVING LINES/DATA)
Message 4 of 10
C3D_TomR
From a non-Autodesk employee perspective, the problem appears to be a forced buffer around the text similar to the offset applied for background masking. This issue isn't limited to just the 2012 version of the software. These offsets can be set in an AutoCAD table style but not a Civil 3D table style.
--Tom
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 5 of 10
Victoria.Studley
Hi @caddie99,
Thank you for posting the screenshots for clarification.
One of our Civil 3D specialists tested this in 2012 and 2015, but could only accomplish what you're trying to do in 2015. As @C3D_TomR mentioned, you may be able to control this by adjusting the AutoCAD Table Style. The adjustment is tricky, as the title, data, and header all need to be the same size. (Again, this only worked in 2015, not in 2012.)
Victoria Studley
Message 6 of 10
Jason.Ferrelli
Autodesk Support
Autodesk Support
Yes, the spacing between the text and the top / bottom of cells are hardcoded for Civil object related tables.
Jason Ferrelli
Message 7 of 10
C3D_TomR
So should we post up needing access to this offset on the Civil 3D Idea Station forum?
Tom Richardson
Twitter | LinkedIn
Message 8 of 10
Jason.Ferrelli
Autodesk Support
Autodesk Support
I think that would be a great idea to submit that on the IdeaStation.
I am sure a that  topic will also open up some other interesting enhancements users would like to see for tables as well.
Civil 3D IdeaStation
Jason Ferrelli
Message 9 of 10
caddie99
yes it is now a request
Message 10 of 10
C3D_TomR
I didn't see anything posted on the Civil 3D Idea Station forum so I created the request myself. Here's a link so please go add kudos to the post so we can get Autodesk to accept it and get it to the development team.
http://forums.autodesk.com/t5/autocad-civil-3d-ideastation/civil-3d-tables-need-a-setting-for-paddin...
Tom Richardson
Twitter | LinkedIn
