Can someone please tell me why this drawing will not load, it just tells that was a problem and gives no helpful information.
I do not see how to attach an drawing so below is a dropbox link
https://dl.dropboxusercontent.com/u/17374049/BLDG-30_COMP_GEOREF.dwg
Solved by jeffHGCE. Go to Solution.
No issues are being reported in AUtoCAD on my Windows PC: try uploading your file to the autocad360 site instead of DropBox and see if the issues to are encountering go away.
Thanks sorry I meant not opening and it finally did, but this one just keeps telling sorry could open file please try again.
This second file is also fine, but it is a much smaller in size and does not contain much except what you see here
The first drawing was referenced into the second and would not open so I tried separating them and I still cannot get it open.
Is that picture opening the drawing in AutoCAD or AutoCAD 360? I can open it fine in AutoCAD but need to open it in AutoCAD 360.
I am testing with windows 10 since tat is what they are using and must be something with windows version.
I removed xrefs, removed dynamic blocks, and still will not open and have to keep guessing or just give up and find another solution since the generic error message is absolutely no help at all.
