As a interim solution, you may have to copy the files locally to the winxp
system, modify and copy back.
If you can open, modify but not save to the win2k machine but save
locally, you've eliminated that your autocad is at fault, (obvious, i
know) I would suspect it's a rights issue on the shared folder. On Win2k,
you can assign rights to individual files as well as folders. Do the
rights on the files allow other users to modify them? Is the login used on
the WinXP system part of the users allowed to modify files on the shared
folder/files? Is the new machine, included in a group to allow write
access to the shared folder? Ensure that modify access has been granted to
the shared folder/files. Maybe you've run throught these already, but if
so, we can eliminate it from the cause.
> Hello RealJD,
> Yes I can save files on the Local Machine.
> I can modify and copy but cannot save once modified.
> I am using WINXP Pro and the machine with the Acad files is on Win2000.
> I can access others files and folders on the shared machine.
> KJG
