AutoCAD 2000/2000i/2002 Archive (Read Only)
3715 Views, 4 Replies
open temp file
How can I open An AutoCad temp. file as an
autocad drawing file
4 REPLIES 4
Change the extension to .dwg.
I've tried changing the file extension to "dwg"
did not work
First, you have to set Windows Explorer to show you the file extensions.
Then you can rename the extensions.
PLUS, in case you don't know, BAK and SV$ are the only extensions you can
rename to DWG, nothing else, not even those AC$ that show up everywhere.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Thanks, change the windows explorer to show file
extension. it worked
