Olá, preciso de ajuda urgente, estou com problemas para instalar o 3Ds max e não sei qual é o problema. Vou postas o log da intalação aqui e a imagem de erro que esta dando. Baixei direto do site da autodesk na versão estudantil.
2016/3/15:20:31:46 fagun DESKTOP-EUQN4P4 === Setup started on DESKTOP-EUQN4P4 by fagun ===
2016/3/15:20:31:46 fagun DESKTOP-EUQN4P4 Path_Length: 153
2016/3/15:20:31:46 fagun DESKTOP-EUQN4P4 Current Directory C:\Users\fagun\AppData\Local\Temp\_AI18E3.tmp
2016/3/15:20:31:46 fagun DESKTOP-EUQN4P4 Launch
2016/3/15:20:31:47 fagun DESKTOP-EUQN4P4 Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/3/15:20:31:48 fagun DESKTOP-EUQN4P4 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/3/15:20:31:48 fagun DESKTOP-EUQN4P4 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/3/15:20:32:24 fagun DESKTOP-EUQN4P4 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/3/15:20:32:24 fagun DESKTOP-EUQN4P4 PageOpen LaunchDialog
2016/3/15:20:32:30 fagun DESKTOP-EUQN4P4 PageOpen LicenseDialog
2016/3/15:20:32:30 fagun DESKTOP-EUQN4P4 PageOpen ProductInfoDialog
2016/3/15:20:32:30 fagun DESKTOP-EUQN4P4 PageOpen ProductSelectionDialog2
2016/3/15:20:32:42 fagun DESKTOP-EUQN4P4 PageOpen FullProgressDialog
2016/3/15:20:32:42 fagun DESKTOP-EUQN4P4 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/3/15:20:32:42 fagun DESKTOP-EUQN4P4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/3/15:20:32:43 fagun DESKTOP-EUQN4P4 Download Play VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/3/15:20:32:48 fagun DESKTOP-EUQN4P4 Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/3/15:20:32:48 fagun DESKTOP-EUQN4P4 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/3/15:20:32:51 fagun DESKTOP-EUQN4P4 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/3/15:20:32:52 fagun DESKTOP-EUQN4P4 Download Play VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/3/15:20:32:58 fagun DESKTOP-EUQN4P4 Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/3/15:20:32:58 fagun DESKTOP-EUQN4P4 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/3/15:20:32:58 fagun DESKTOP-EUQN4P4 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/3/15:20:32:59 fagun DESKTOP-EUQN4P4 Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/3/15:20:33:04 fagun DESKTOP-EUQN4P4 Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/3/15:20:33:04 fagun DESKTOP-EUQN4P4 Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/3/15:20:33:08 fagun DESKTOP-EUQN4P4 Install DirectX® Runtime Succeeded
2016/3/15:20:33:09 fagun DESKTOP-EUQN4P4 Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/3/15:20:43:41 fagun DESKTOP-EUQN4P4 Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/3/15:20:43:41 fagun DESKTOP-EUQN4P4 Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/3/15:20:43:42 fagun DESKTOP-EUQN4P4 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/3/15:20:43:42 fagun DESKTOP-EUQN4P4 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/3/15:20:43:42 fagun DESKTOP-EUQN4P4 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Parece ter havido algum erro no instalador.
Tente fazer o download novamente. Use a opção "Download Now" ao invés de "Install Now".
Me dê um retorno sobre o sucesso ou não da instalação.
att
Prof. Dr. Marcos Thadeu Queiroz Magalhães
Dean of the Faculty of Architecture and Urbanism
Fau-UnB Homepage
LinkedIn
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
