Tentei instalar o 3D Max 2018 versão de estudante em PT e EN, mas ambos deram erro. Tenho o Maya 2018 e não houve erro na instalação.
Segue abaixo o log de instalação e imagem dos erros:
2017/8/11:23:59:35 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2017/8/11:23:59:35 Rodrigo RODRIGO Launch
2017/8/11:23:59:35 Rodrigo RODRIGO CommandLine /akamai /sid a1b3A00000B95O5QAJ /skipEULA /url "http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/Auto..."
2017/8/12:00:01:22 Rodrigo RODRIGO === Setup ended ===
2017/8/11:23:59:39 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2017/8/11:23:59:39 Rodrigo RODRIGO Launch
2017/8/11:23:59:40 Rodrigo RODRIGO Download Play SETUPMARKER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/11:23:59:40 Rodrigo RODRIGO Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/11:23:59:41 Rodrigo RODRIGO Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:01:21 Rodrigo RODRIGO Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:01:22 Rodrigo RODRIGO PageOpen LaunchDialog
2017/8/12:00:06:13 Rodrigo RODRIGO PageOpen LicenseDialog
2017/8/12:00:06:13 Rodrigo RODRIGO PageOpen ProductInfoDialog
2017/8/12:00:06:14 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2017/8/12:00:12:34 Rodrigo RODRIGO PageOpen FullProgressDialog
2017/8/12:00:12:35 Rodrigo RODRIGO Download Play STARTMARKER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:35 Rodrigo RODRIGO Download Complete STARTMARKER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:35 Rodrigo RODRIGO Download Play VCREDIST2012X86 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:38 Rodrigo RODRIGO Download Complete VCREDIST2012X86 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:38 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/8/12:00:12:43 Rodrigo RODRIGO Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
2017/8/12:00:12:43 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/8/12:00:12:43 Rodrigo RODRIGO Download Play VCREDIST2012X64 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:46 Rodrigo RODRIGO Download Complete VCREDIST2012X64 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:46 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/8/12:00:12:48 Rodrigo RODRIGO Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
2017/8/12:00:12:48 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/8/12:00:12:48 Rodrigo RODRIGO Download Play VCREDIST2013X86 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:52 Rodrigo RODRIGO Download Complete VCREDIST2013X86 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:52 Rodrigo RODRIGO Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x86_2013.log
2017/8/12:00:12:55 Rodrigo RODRIGO Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2017/8/12:00:12:55 Rodrigo RODRIGO Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2017/8/12:00:12:55 Rodrigo RODRIGO Download Play VCREDIST2013X64 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:59 Rodrigo RODRIGO Download Complete VCREDIST2013X64 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:12:59 Rodrigo RODRIGO Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x64_2013.log
2017/8/12:00:13:02 Rodrigo RODRIGO Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2017/8/12:00:13:02 Rodrigo RODRIGO Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2017/8/12:00:13:02 Rodrigo RODRIGO Download Play CM http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:14:56 Rodrigo RODRIGO Download Complete CM http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:14:56 Rodrigo RODRIGO Installing Autodesk® Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:00:15:47 Rodrigo RODRIGO Install Autodesk® Material Library 2018 Succeeded
2017/8/12:00:15:48 Rodrigo RODRIGO Download Play CMILB http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:16:24 Rodrigo RODRIGO Download Complete CMILB http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:16:24 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:00:17:08 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/8/12:00:17:09 Rodrigo RODRIGO Download Play CMILM http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:26:03 Rodrigo RODRIGO Download Complete CMILM http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:26:03 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:00:27:13 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Medium Resolution Library Succeeded
2017/8/12:00:27:14 Rodrigo RODRIGO Download Play CMAIL http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:28:02 Rodrigo RODRIGO Download Complete CMAIL http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:28:02 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:00:28:14 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Advanced Material Image Library Succeeded
2017/8/12:00:28:14 Rodrigo RODRIGO Download Play MAX http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:31:43 Rodrigo RODRIGO Download Aborted MAX http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:00:31:43 Rodrigo RODRIGO Install Autodesk® 3ds Max® 2018 Failed Download Failed, Installation aborted, Result=1603
2017/8/12:00:31:47 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Advanced Material Image Library Succeeded
2017/8/12:00:31:55 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Medium Resolution Library Succeeded
2017/8/12:00:32:02 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/8/12:00:32:36 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 Succeeded
2017/8/12:00:32:36 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2017/8/12:00:32:37 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2017/8/12:00:32:37 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/8/12:00:32:38 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/8/12:00:32:39 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2017/8/12:01:06:39 Rodrigo RODRIGO === Setup ended ===
2017/8/12:01:16:54 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2017/8/12:01:16:54 Rodrigo RODRIGO Launch
2017/8/12:01:16:54 Rodrigo RODRIGO CommandLine /akamai /sid a1b3A00000B95dyQAB /skipEULA /url "http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/Auto..."
2017/8/12:01:17:33 Rodrigo RODRIGO === Setup ended ===
2017/8/12:01:16:57 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2017/8/12:01:16:57 Rodrigo RODRIGO Launch
2017/8/12:01:17:32 Rodrigo RODRIGO Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:17:32 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:17:33 Rodrigo RODRIGO PageOpen LaunchDialog
2017/8/12:01:18:03 Rodrigo RODRIGO PageOpen LicenseDialog
2017/8/12:01:18:03 Rodrigo RODRIGO PageOpen ProductInfoDialog
2017/8/12:01:18:03 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2017/8/12:01:18:28 Rodrigo RODRIGO PageOpen FullProgressDialog
2017/8/12:01:18:28 Rodrigo RODRIGO Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:18:28 Rodrigo RODRIGO Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:18:28 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/8/12:01:18:35 Rodrigo RODRIGO Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
2017/8/12:01:18:35 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/8/12:01:18:35 Rodrigo RODRIGO Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:18:35 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/8/12:01:18:36 Rodrigo RODRIGO Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
2017/8/12:01:18:36 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/8/12:01:18:36 Rodrigo RODRIGO Download Skipped VCREDIST2013X86 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:18:36 Rodrigo RODRIGO Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x86_2013.log
2017/8/12:01:18:39 Rodrigo RODRIGO Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2017/8/12:01:18:39 Rodrigo RODRIGO Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2017/8/12:01:18:39 Rodrigo RODRIGO Download Skipped VCREDIST2013X64 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:18:39 Rodrigo RODRIGO Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x64_2013.log
2017/8/12:01:18:40 Rodrigo RODRIGO Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2017/8/12:01:18:40 Rodrigo RODRIGO Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2017/8/12:01:18:41 Rodrigo RODRIGO Download Skipped CM http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:18:41 Rodrigo RODRIGO Installing Autodesk® Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:19:16 Rodrigo RODRIGO Install Autodesk® Material Library 2018 Succeeded
2017/8/12:01:19:17 Rodrigo RODRIGO Download Skipped CMILB http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:19:17 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:20:09 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/8/12:01:20:09 Rodrigo RODRIGO Download Skipped CMILM http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:20:09 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:21:13 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Medium Resolution Library Succeeded
2017/8/12:01:21:14 Rodrigo RODRIGO Download Skipped CMAIL http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:21:14 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:21:27 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Advanced Material Image Library Succeeded
2017/8/12:01:21:27 Rodrigo RODRIGO Download Play MAX http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:26:19 Rodrigo RODRIGO Download Complete MAX http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:26:20 Rodrigo RODRIGO Installing Autodesk® 3ds Max® 2018: TRANSFORMS="C:\Users\Rodrigo\AppData\Local\Temp\_AI3AA0.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:38:52 Rodrigo RODRIGO Install Autodesk® 3ds Max® 2018 Succeeded
2017/8/12:01:38:54 Rodrigo RODRIGO Download Play MENTALRAYPLUG http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:38:56 Rodrigo RODRIGO Download Complete MENTALRAYPLUG http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:38:56 Rodrigo RODRIGO Installing NVIDIA mental ray and IRay feature plugins for 3ds Max 2018: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:39:03 Rodrigo RODRIGO Install NVIDIA mental ray and IRay feature plugins for 3ds Max 2018 Succeeded
2017/8/12:01:39:03 Rodrigo RODRIGO Installing Arnold Renderer for Autodesk® 3ds Max® 2018 (MAXtoA): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:39:08 Rodrigo RODRIGO Install Arnold Renderer for Autodesk® 3ds Max® 2018 (MAXtoA) Succeeded
2017/8/12:01:39:08 Rodrigo RODRIGO Download Play BACKBURNER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:39:23 Rodrigo RODRIGO Download Complete BACKBURNER http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:39:23 Rodrigo RODRIGO Installing Autodesk® Backburner 2018: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:40:05 Rodrigo RODRIGO Install Autodesk® Backburner 2018 Succeeded
2017/8/12:01:40:06 Rodrigo RODRIGO Download Play INVENTOR_ENGINE http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:40:59 Rodrigo RODRIGO Download Complete INVENTOR_ENGINE http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:41:00 Rodrigo RODRIGO Installing Autodesk® Inventor Server Engine For 3ds Max 2018: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/8/12:01:42:03 Rodrigo RODRIGO Install Autodesk® Inventor Server Engine For 3ds Max 2018 Succeeded
2017/8/12:01:42:03 Rodrigo RODRIGO Download Play RXM2018 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:44:39 Rodrigo RODRIGO Download Aborted RXM2018 http://efulfillment.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B8...
2017/8/12:01:44:39 Rodrigo RODRIGO Install Autodesk® Revit® 2018 Interoperability for Autodesk® 3ds Max 2018 Failed Download Failed, Installation aborted, Result=1603
2017/8/12:01:45:00 Rodrigo RODRIGO Rollback Autodesk® Inventor Server Engine For 3ds Max 2018 Succeeded
2017/8/12:01:45:24 Rodrigo RODRIGO Rollback Autodesk® Backburner 2018 Succeeded
2017/8/12:01:45:26 Rodrigo RODRIGO Rollback Arnold Renderer for Autodesk® 3ds Max® 2018 (MAXtoA) Succeeded
2017/8/12:01:45:28 Rodrigo RODRIGO Rollback NVIDIA mental ray and IRay feature plugins for 3ds Max 2018 Succeeded
2017/8/12:01:52:51 Rodrigo RODRIGO Rollback Autodesk® 3ds Max® 2018 Succeeded
2017/8/12:01:52:54 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Advanced Material Image Library Succeeded
2017/8/12:01:53:00 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Medium Resolution Library Succeeded
2017/8/12:01:53:06 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/8/12:01:54:36 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 Succeeded
2017/8/12:01:54:36 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2017/8/12:01:54:37 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2017/8/12:01:54:37 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/8/12:01:54:38 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/8/12:01:54:39 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2017/8/12:02:16:05 Rodrigo RODRIGO === Setup ended ===
2017/9/10:19:23:42 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2017/9/10:19:23:42 Rodrigo RODRIGO Launch
2017/9/10:19:23:42 Rodrigo RODRIGO CommandLine /PK 128J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/Autodesk..."
2017/9/10:19:25:42 Rodrigo RODRIGO === Setup ended ===
2017/9/10:19:23:45 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2017/9/10:19:23:45 Rodrigo RODRIGO Launch
2017/9/10:19:24:46 Rodrigo RODRIGO Download Play SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:24:47 Rodrigo RODRIGO Download Complete SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:24:47 Rodrigo RODRIGO Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:25:40 Rodrigo RODRIGO Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:25:42 Rodrigo RODRIGO PageOpen LaunchDialog
2017/9/10:19:25:53 Rodrigo RODRIGO PageOpen LicenseDialog
2017/9/10:19:25:53 Rodrigo RODRIGO PageOpen ProductInfoDialog
2017/9/10:19:25:54 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2017/9/10:19:26:01 Rodrigo RODRIGO PageOpen FullProgressDialog
2017/9/10:19:26:01 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:26:02 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:26:02 Rodrigo RODRIGO Download Play VCREDIST2012X86 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:26:05 Rodrigo RODRIGO Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:26:05 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/9/10:19:28:03 Rodrigo RODRIGO Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
2017/9/10:19:28:03 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/9/10:19:28:04 Rodrigo RODRIGO Download Play VCREDIST2012X64 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:28:06 Rodrigo RODRIGO Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:28:06 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/9/10:19:28:46 Rodrigo RODRIGO Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
2017/9/10:19:28:46 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/9/10:19:28:47 Rodrigo RODRIGO Download Play VCREDIST2013X86 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:28:49 Rodrigo RODRIGO Download Complete VCREDIST2013X86 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:28:49 Rodrigo RODRIGO Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x86_2013.log
2017/9/10:19:29:32 Rodrigo RODRIGO Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2017/9/10:19:29:32 Rodrigo RODRIGO Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2017/9/10:19:29:33 Rodrigo RODRIGO Download Play VCREDIST2013X64 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:29:36 Rodrigo RODRIGO Download Complete VCREDIST2013X64 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:29:36 Rodrigo RODRIGO Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x64_2013.log
2017/9/10:19:30:38 Rodrigo RODRIGO Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2017/9/10:19:30:38 Rodrigo RODRIGO Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2017/9/10:19:30:42 Rodrigo RODRIGO Download Play CM http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:31:55 Rodrigo RODRIGO Download Complete CM http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:31:55 Rodrigo RODRIGO Installing Autodesk® Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/10:19:32:46 Rodrigo RODRIGO Install Autodesk® Material Library 2018 Succeeded
2017/9/10:19:32:47 Rodrigo RODRIGO Download Play CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:33:06 Rodrigo RODRIGO Download Complete CMILB http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:33:06 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/10:19:33:49 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/9/10:19:33:50 Rodrigo RODRIGO Download Play CMILM http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:36:52 Rodrigo RODRIGO Download Complete CMILM http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:36:52 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/10:19:38:41 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Medium Resolution Library Succeeded
2017/9/10:19:38:42 Rodrigo RODRIGO Download Play CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:39:07 Rodrigo RODRIGO Download Complete CMAIL http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:39:07 Rodrigo RODRIGO Installing Autodesk® Material Library 2018 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2018" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0764-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/10:19:39:20 Rodrigo RODRIGO Install Autodesk® Material Library 2018 - Advanced Material Image Library Succeeded
2017/9/10:19:39:21 Rodrigo RODRIGO Download Play MAX http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:45:19 Rodrigo RODRIGO Download Aborted MAX http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{3B81B1B...
2017/9/10:19:45:19 Rodrigo RODRIGO Install Autodesk® 3ds Max® 2018 Failed Download Failed, Installation aborted, Result=1603
2017/9/10:19:45:29 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Advanced Material Image Library Succeeded
2017/9/10:19:45:39 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Medium Resolution Library Succeeded
2017/9/10:19:45:47 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/9/10:19:46:46 Rodrigo RODRIGO Rollback Autodesk® Material Library 2018 Succeeded
2017/9/10:19:46:47 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2017/9/10:19:46:47 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2017/9/10:19:46:48 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/9/10:19:46:49 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Obrigado por tentarem ajudar!!
Solucionado! Ir para Solução.
Solucionado por Binga. Ir para Solução.
Olá @Anonymous
Provavelmente é problema de conexão.
Tenta fazer a instalação via Virtual Agent.
Veja como aqui: forums.autodesk.com/t5/instalacao-e-ativacao-portugues/fazer-o-download-utilizando-virtual-agent/td-p/6299268
Depois avisa se deu certo.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
