Sheets wont publish to project
Message 1 of 10
Publishing model & include all sheets, full sheet set, small sheet set, the project gets stuck in 'Processing: sheet Views" forever, Revit freezes & screen eventually ghosts
Replies (9)
Message 2 of 10
don_simpson
Hello BMOORE,
Thank you for contacting Autodesk.
What version of Revit is currently being used?
What is the current version of Assemble publisher? See the "About" button in Assemble tab in Revit?
Would it be possible to direct message the Revit file to me for troubleshooting?
Don
Don Simpson
Technical Support
Message 3 of 10
don_simpson
Hello BMOORE,
I wanted to check-in again. Did you have any additional information to regards to the questions posted in my earlier post? Please see below.
Don
Don Simpson
Technical Support
Message 4 of 10
don_simpson
Hello BMOORE,
I wanted to check-in again. Do you still need assistance? Did you have any additional information to regards to the questions posted in my earlier post? Please see below.
Would it be possible to direct message the Revit file to me, if troubleshooting is still needed?
Don
Don Simpson
Technical Support
Message 5 of 10
Hi Don! Yes still having trouble publishing sheets. Below are Egnyte links to the files. I can publish the sheets without the architectural background attached (which does me no good) and it still continues to get caught up with background model loaded.
Main/sheet Model - 'Assemble Test-South.rvt'
https://files.powerdesigninc.us/dl/itNUG3D4OE
Linked Models
https://files.powerdesigninc.us/fl/Qhr4zesShs
Message 6 of 10
don_simpson
Hello BMOORE,
Would it possible to upgrade the version of the Revit model from 2017 to a new version, 2018 or 2019?
The issue can be reproduced in the Revit 2017 version of the file. In upgrading the file to Revit 2019 and testing within a test project, the sheets appear to publish as expected.
Don
Don Simpson
Technical Support
Message 7 of 10
don_simpson
Hello BMOORE,
Please see my response below after testing with these files. Please let me know if you have any questions or concerns or if this issue may be considered resolved.
Don
Hello BMOORE,
Don
Don Simpson
Technical Support
Message 8 of 10
Good Morning, I have upgraded the project to 2018 in hopes that I could make it work as we have several projects in that format currently. Having to upgrade to 2019 for every project will not be a great selling point during our evaluation of the proeduct. Is this just due to the models we are working with on this project?
Message 9 of 10
arian.saeedfar
Hi Bradley,
I totally understand your concern. In your case, we believe that the issue is related to this specific model and we currently do not see any general issues with publishing models from Revit 2017. What makes it difficult to understand where the issue comes from in your model is that it freezes on the sheet processing without generating any errors. I suspect that the problem sheet might be the sheet "Site Plan", but I'm not entirely sure. Therefore, upgrading the model in this case would be the most reliable solution. Please let us know if you saw this issue in any other models.
Thanks!
Arian
Message 10 of 10
OK. Upgrading to 2019 now & will give it another go. Will keep you posted
