Prioritize GPU, but fallback to CPU if not available
am_wilkins
Message 1 of 8
am_wilkins
I was wondering if there was a way or plans to implement a "pseudo-XPU" system for Arnold GPU.
My thoughts were that you can choose to prioritize rendering on a GPU if available, however if there isn't a GPU then Arnold will fall-back to the CPU.
This way a job can be submitted to a CPU and GPU based render farm and succeed rendering on either systems.
All the best,
amwilkins
Accepted solutions (3)
Replies (7)
Message 2 of 8
Stephen.Blair
On the Device tab
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
am_wilkins
Hi Stephen,
Oh wow... I had completely missed that for some reason, that's what I get for posting before double-checking.
Thanks very much, we'll try it out. 👍
amwilkins
Message 4 of 8
am_wilkins
Finally managed to get around to testing this, however it doesn't appear to work.
Setting the Fallback Device to CPU, and submitted a render job to CPU only nodes gets me these errors:
Node #1 example:
ERROR   | [gpu] no compatible NVIDIA GPUs found (GPU-rendering)
WARNING | [kick] render aborted due to earlier errors
Node #2 example: (yes, drivers are out of date)
ERROR   | [gpu] NVIDIA driver 512.15 is too old, version 537.13 or higher required (GPU-rendering)
In any event, Arnold doesn't flip over to CPU and starting rendering.
Any reason why this wouldn't be working?
I tried various device expressions using just "*" or trying to specify certains cards (btw documents aren't well updated for this except the C4D ones.)
all the best,
amwilkins
Houdini Core Version 20.5.410
Arnold Core: 7.3.6.0
HotA: 6.3.6.0
CPU: AMD Ryzen TR 3990x / 3970x
RAM: 128GB
GPU: NVIDIA RTX 4090 / RTX A4000
OS: Windows/Linux
Message 5 of 8
DeclanRussell
Hi am_wilkins,
It seems currently that Arnold is assuming that you have a GPU compatible system before doing the checks for the fallback. Its currently working more like this: If I have a GPU compatible system, but no GPU matches the search criteria of the gpu_default_names regex or gpu_default_min_memory_MB threshold, then apply the fallback rules. I've made ARNOLD-16277 to add the case where you may not have a GPU compatible system to follow the fallback rules.
Message 6 of 8
am_wilkins
Okay thanks, yes that would be ideal.
Usually in a farm setup with a mix of cpu and gpu, the cpu machines would generally either have old or on-board GPU, etc.
Message 7 of 8
thiago.ize
Hi, this was fixed in the just released arnold core 7.4.3.0:
  • CPU fallback when no supported GPU found: Arnold falls back to CPU rendering according to the value of the render_device_fallback option when there are no supported GPUs. (ARNOLD-16277)
Message 8 of 8
am_wilkins
Good day,
Okay awesome, will get us updated to this latest release and try test this again.
Thank you.
