I'm getting gpu fatal error occurred
Message 1 of 19
I have 1660 TI 6gb gpu and whenever I try to render with gpu I always get this error. When I try to render sequence, few frames get rendered but after that arnold automatically stops rendering. it doesn't render all frames. but I could able to render only single frame using gpu but it works for few minutes if I try to render single frame often it gives me error. I'm using latest drivers. today I thought let's try out nvidia's creator driver to see if it solve my problem or not but creator drivers are more worse. its taking a lot of time plus its giving me error more then before. CPU Render Works completely Fine. Need Solution For It. Thanks.
Replies (18)
Message 2 of 19
Stephen.Blair
Can you get an Arnold log?
Instructions for generating full verbosity log files are available for MtoA, MaxtoA, C4DtoA, HtoA, KtoA, and Kick.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 19
Message 4 of 19
here it is Arnold Log.txt
Message 5 of 19
Arnold GPU Fatal Error Check this video. Please don't tell me to restart maya and check. I have already done this so many times. It gives same error again and again. need permanent solution. I have latest mtoa arnold version. mtoa : 4.2.1 Arnold 6.2.0.1, Maya 2022.
Here's my laptop specifications : Acer Predator Helios 300 Gaming Laptop PC, 15.6 inches Full HD 144Hz 3ms IPS Display, Intel i7-9750H, GTX 1660 Ti 6GB, 16GB DDR4 (Single Stick), 256GB PCIe NVMe SSD, Backlit Keyboard, PH315-52-78VL
Message 6 of 19
thiago.ize
It probably won't help for this bug, but you might like to know you're no longer running the latest version. You can upgrade your mtoa 4.2.1 to 4.2.2. Even if that doesn't fix this particular bug, hopefully it'll give other GPU or CPU improvements you can enjoy.
Message 7 of 19
I'm using latest Mtoa 4.2.1 and latest Nvidia Drivers, Maya 2022
Latest Nvidia DriversI
Message 8 of 19
thiago.ize
4.2.1 isn't the latest. You can upgrade here to 4.2.2 https://www.arnoldrenderer.com/arnold/download/
Message 9 of 19
Ok let me try it out now.
Message 10 of 19
mtoa 4.2.2 gpu fatal error Check this link. I have installed mtoa 4.2.2 still It's giving me same error. nothing changed. cpu render works fine. but i want to do gpu render. I have a good gpu but because of this error it's useless.
Message 11 of 19
Message 12 of 19
thiago.ize
Nice to see it's such a simple scene! Can you upload that here so we can try to reproduce it?
Message 13 of 19
https://drive.google.com/file/d/1rF5dqQnq9-iEfwnGKknbJhbHIOE5oOtw/view?usp=sharing
Here it it. I was trying some tests on simple animation. it always gives me gpu fatal error with complex animation and heavy scene.
Message 14 of 19
thiago.ize
Could you change the permissions of that so anyone with the google drive link can access it?
Message 15 of 19
Yes i changed it. Anyone can download it now.
Message 16 of 19
thiago.ize
I tried the same maya and mtoa version along with various driver versions, but I could not get it to crash on my gpus. Are you overclocking the GPU? Could the GPU be overheating after all those rendered frames? Another possibility is that this crash might require your specific GPU (I tried a P6000 and RTX 6000)?
Sorry I couldn't be of more help.
Message 17 of 19
Hey, I'm not overclocking my gpu. My laptop has turbo button, if I turn it on, It overclocks my gpu + doubles the fan speed. But that's not the case. I get error without turbo mode. I have saw on internet that many people already faced this problem with same gpu(1660 TI) but none of them got any solution. Maybe gpu rendering is not compatible with this specific gpu GTX 1660 TI?
Message 18 of 19
But one thing i have noticed that after installing mtoa 4.2.2 it's crashing less than before. Before that it was crashing many times. But now it is still crashes but it's less crashing compared to the past version. I have tried to render this cube test 10 times and the result was this : 7-8 times gpu render works fine it rendered all frames. but it gave me an error 2-3 times. So I just told you the approximate gpu fatal error chances.
Message 19 of 19
I don't know how it would handle complex scenes. I think it's gonna give me fatal error cuz cube test is a very simple scene. Did you tried it on 1660 ti? I think that specific gpu could have some compatibility issues. Thanks for your time and efforts I'm really happy to see how fast you are trying to sort out my problem 🙂
