Unable to dynamically load : C:/solidangle/mtoadeploy/2017/plug-ins/mtoa.mll (3.x Arnold)
Message 1 of 10
Maya 2017 update 5, 2.x version of Arnold loading fine... Have run dependency walker, hope I am using it right... can attach if somebody wouldn't mind having a look...
Replies (9)
Message 2 of 10
Stephen.Blair
Open a command prompt from inside Maya, and then run depends.exe
In MEL: system("start cmd /K")
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
Ok the dependancy walker, app loads up and I load mtoa.dll? right? I saved out the image file, too big, 10mb to upload, so shall I do a screen grab... ? Thanks a lot.
Message 4 of 10
Stephen.Blair
mtoa.mll
Save a dwi file. It should be < 3MB
and < 1MB if you zip it.
// Stephen Blair
Message 5 of 10
Thanks for your time Stephen, the dwi file is 35mb! here is a grab that might give the info...
Message 6 of 10
Stephen.Blair
Ok, if you open a command prompt from inside Maya, then the DWI will be big...because almost all the dependencies will be resolved.
Rather that uploading that large file, let's use Process Monitor instead.
https://arnoldsupport.com/2018/03/27/mtoa-getting-a-process-monitor-log-to-troubleshoot-problems-loa...
Upload the zipped Process Monitor log somewhere and I'll take a look
// Stephen Blair
Message 7 of 10
logfile2.zip Think I did it right... weirdly Maya is listed under winlogon and explorer etc unlike the youtube vid.
Message 8 of 10
Stephen.Blair
I start Maya by double-clicking a batch file on the desktop, so the process hierarchy will be different
// Stephen Blair
Message 9 of 10
Stephen.Blair
What version of MtoA are you using? 3.0.1 ?
The problem is a conflicting version of the optix.1.dll:
C:\Program Files\Adobe\Adobe After Effects CC 2014\Support Files\optix.1.dll
If you're still using that After Effects, can you remove it from PATH so that MtoA doesn't find it?
// Stephen Blair
Message 10 of 10
Thanks Stephen, 3.0.2 and that worked once I removed the path.
Using this helpful software...
https://rix0rrr.github.io/WindowsPathEditor/
Sorry time difference, hence the delay in response, really appreciate the help.
Thanks again.
