Sample API scene not giving same results as tutorial
AaronWPowell
Message 1 of 10
AaronWPowell
I copied + pasted the code for "Creating and rendering a scene" (https://docs.arnoldrenderer.com/display/A5ARP/Creating+and+Rendering+a+Scene) and converted to Python, but the results I'm getting aren't anything like the example render on the web page (see attached image for comparison and log). For the record, I'm not completely new to the API but I'm writing some tools in Python that take advantage of the Arnold API and trying to compare the results I get with my code vs the vanilla version, so I'm confused as to why this simple scene is just totally breaking on me.
The polymesh plane is missing completely, and the image is way too dark. It seems like an issue with color space transformation, but even if I render the image to EXR and change the color space in Nuke it still doesn't look right (ie, the specular highlight on the red ball is way too small in my render vs the example).
I'm using the 7.1.2.0 SDK on Windows 10 and have no custom OCIO environment variable set.
Replies (9)
Message 2 of 10
Stephen.Blair
That example would have be done with an older Arnold, so I wouldn't expect it to match.
You could export an ass file and kick it with different versions.
This is what it will look like when we update the docs:
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
AaronWPowell
Thanks for the heads up @Stephen.Blair. I can work through the color management issues I think, but I'm more concerned about constructing the polymesh - there's nothing in the example code that looks particularly off to me, but do you know if there's something different that has to be done to properly add the polymesh data to get the result you shared?
Message 4 of 10
Stephen.Blair
Try with this code:
#include <ai.h>
int main()
   AiBegin();
   // create anew universe to create objects in
   AtUniverse *universe = AiUniverse();
   // start an Arnold session, log to both a file and the console
   AtRenderSession *session = AiRenderSession(universe,  AI_SESSION_BATCH);
   AiMsgSetLogFileName("scene1.log");
   AiMsgSetConsoleFlags(universe, AI_LOG_ALL);
   AiMsgSetLogFileFlags(universe, AI_LOG_ALL);
   // create a sphere geometric primitive
   AtNode *sph = AiNode(universe, AtString("sphere"),  AtString("mysphere"));
   AiNodeSetVec(sph, AtString("center"), 0.0f, 4.0f, 0.0f);
   AiNodeSetFlt(sph, AtString("radius"), 4.0f);
   // create a polymesh, with UV coordinates
   AtNode *mesh = AiNode(universe, AtString("polymesh"), AtString("mymesh"));
   AtArray* nsides_array = AiArray(1, 1, AI_TYPE_UINT, 4);
   AiNodeSetArray(mesh, AtString("nsides"), nsides_array);
   AtArray* vlist_array = AiArray(12, 1, AI_TYPE_FLOAT, -10.f, 0.f, 10.f, 10.f, 0.f, 10.f, -10.f, 0.f, -10.f, 10.f, 0.f, -10.f);
   AiNodeSetArray(mesh, AtString("vlist"), vlist_array);
   AtArray* vidxs_array = AiArray(4, 1, AI_TYPE_UINT, 0, 1, 3, 2);
   AiNodeSetArray(mesh, AtString("vidxs"), vidxs_array);
   AtArray* uvlist_array = AiArray(8, 1, AI_TYPE_FLOAT, 0.f, 0.f, 1.f, 0.f, 1.f, 1.f, 0.f, 1.f);
   AiNodeSetArray(mesh, AtString("uvlist"), uvlist_array);
   AtArray* uvidxs_array = AiArray(4, 1, AI_TYPE_UINT, 0, 1, 2, 3);
   AiNodeSetArray(mesh, AtString("uvidxs"), uvidxs_array);
   // create a red standard surface shader
   AtNode *shader1 = AiNode(universe, AtString("standard_surface"), AtString("myshader1"));
   AiNodeSetRGB(shader1, AtString("base_color"), 1.0f, 0.02f, 0.02f);
   AiNodeSetFlt(shader1, AtString("specular"), 0.05f);
   // create a textured standard surface shader
   AtNode *shader2 = AiNode(universe, AtString("standard_surface"), AtString("myshader2"));
   AiNodeSetRGB(shader2, AtString("base_color"), 1.0f, 0.0f, 0.0f);
   // create an image shader for texture mapping
   AtNode *image = AiNode(universe, AtString("image"), AtString("myimage"));
   AiNodeSetStr(image, AtString("filename"), AtString("arnold.png"));
   AiNodeSetFlt(image, AtString("sscale"), 4.f);
   AiNodeSetFlt(image, AtString("tscale"), 4.f);
   // link the output of the image shader to the color input of the surface shader
   AiNodeLink(image, AtString("base_color"), shader2);
   // assign the shaders to the geometric objects
   AiNodeSetPtr(sph, AtString("shader"), shader1);
   AiNodeSetPtr(mesh, AtString("shader"), shader2);
   // create a perspective camera
   AtNode *camera = AiNode(universe, AtString("persp_camera"), AtString("mycamera"));
   // position the camera (alternatively you can set 'matrix')
   AiNodeSetVec(camera, AtString("position"), 0.f, 10.f, 35.f);
   AiNodeSetVec(camera, AtString("look_at"), 0.f, 3.f, 0.f);
   AiNodeSetFlt(camera, AtString("fov"), 45.f);
   // create a point light source
   AtNode *light = AiNode(universe, AtString("point_light"), AtString("mylight"));
   // position the light (alternatively use 'matrix')
   AiNodeSetVec(light, AtString("position"), 15.f, 30.f, 15.f);
   AiNodeSetFlt(light, AtString("intensity"), 4500.f); // alternatively, use 'exposure'
   AiNodeSetFlt(light, AtString("radius"), 4.f); // for soft shadows
   // get the global options node and set some options
   AtNode *options = AiUniverseGetOptions(universe);
   AiNodeSetInt(options, AtString("AA_samples"), 8);
   AiNodeSetInt(options, AtString("xres"), 480);
   AiNodeSetInt(options, AtString("yres"), 360);
   AiNodeSetInt(options, AtString("GI_diffuse_depth"), 4);
   // set the active camera (optional, since there is only one camera)
   AiNodeSetPtr(options, AtString("camera"), camera);
   // create an output driver node
   AtNode *driver = AiNode(universe, AtString("driver_jpeg"), AtString("mydriver"));
   AiNodeSetStr(driver, AtString("filename"), AtString("scene1.jpg"));
   // create a gaussian filter node
   AtNode *filter = AiNode(universe, AtString("gaussian_filter"), AtString("myfilter"));
   // assign the driver and filter to the main (beauty) AOV,
   // which is called "RGBA" and is of type RGBA
   AtArray *outputs_array = AiArrayAllocate(1, 1, AI_TYPE_STRING);
   AiArraySetStr(outputs_array, 0, AtString("RGBA RGBA myfilter mydriver"));
   AiNodeSetArray(options, AtString("outputs"), outputs_array);
   // finally, render the image!
   AiRender(session, AI_RENDER_MODE_CAMERA);
   // ... or you can write out an .ass file instead
   // AtParamValueMap* params = AiParamValueMap();
   // AiParamValueMapSetInt(params, AtString("mask"), AI_NODE_ALL);
   // AiSceneWrite(universe, "scene1.ass", params);
   // AiParamValueMapDestroy(params);
   // Arnold session shutdown
   AiRenderSessionDestroy(session);
   AiUniverseDestroy(universe);
   AiEnd();
   return 0;
// Stephen Blair
Message 5 of 10
AaronWPowell
Thanks for the code. I can try to compile it later tonight, but the polymesh code doesn't look fundamentally different from the code in the original example as far as I can tell, so I'm not sure why it's simply not rendering the polymesh plane.
This is the code I have, converted from C to Python.
from arnold import *
# start an Arnold session, log to both a file and the console
AiBegin()
AiMsgSetConsoleFlags(AI_LOG_ALL)
# create a sphere geometric primitive
sph = AiNode("sphere")
AiNodeSetStr(sph, "name", "mysphere")
AiNodeSetVec(sph, "center", 0.0, 4.0, 0.0)
AiNodeSetFlt(sph, "radius", 4.0)
# create a polymesh, with UV coordinates
mesh = AiNode("polymesh")
AiNodeSetStr(mesh, "name", "mymesh")
AiNodeSetArray(mesh, "nsides", nsides_array)
vlist_array = AiArray(12, 1, AI_TYPE_FLOAT, -10, 0, 10, 10, 0, 10, -10, 0, -10, 10, 0, -10)
AiNodeSetArray(mesh, "vlist", vlist_array)
AiNodeSetArray(mesh, "vidxs", vidxs_array)
uvlist_array = AiArray(8, 1, AI_TYPE_FLOAT, 0, 0, 1, 0, 1, 1, 0, 1)
AiNodeSetArray(mesh, "uvlist", uvlist_array)
AiNodeSetArray(mesh, "uvidxs", uvidxs_array)
# create a red standard surface shader
shader1 = AiNode("standard_surface")
AiNodeSetStr(shader1, "name", "myshader1")
AiNodeSetRGB(shader1, "base_color", 1.0, 0.02, 0.02)
AiNodeSetFlt(shader1, "specular", 0.05)
# create a textured standard surface shader
shader2 = AiNode("standard_surface")
AiNodeSetStr(shader2, "name", "myshader2")
AiNodeSetRGB(shader2, "base_color", 1.0, 1.0, 1.0)
# create an image shader for texture mapping
image = AiNode("image")
AiNodeSetStr(image, "name", "myimage")
AiNodeSetStr(image, "filename", "arnold_icon.png")
AiNodeSetFlt(image, "sscale", 4)
AiNodeSetFlt(image, "tscale", 4)
# link the output of the image shader to the color input of the surface shader
#AiNodeLink(image, "base_color", shader2)
# assign the shaders to the geometric objects
AiNodeSetPtr(sph, "shader", shader1)
AiNodeSetPtr(mesh, "shader", shader2)
# create a perspective camera
camera = AiNode("persp_camera")
AiNodeSetStr(camera, "name", "mycamera")
# position the camera (alternatively you can set 'matrix')
AiNodeSetVec(camera, "position", 0, 10, 35)
AiNodeSetVec(camera, "look_at", 0, 3, 0)
AiNodeSetFlt(camera, "fov", 45)
# create a point light source
light = AiNode("point_light")
AiNodeSetStr(light, "name", "mylight")
# position the light (alternatively use 'matrix')
AiNodeSetVec(light, "position", 15, 30, 15)
AiNodeSetFlt(light, "intensity", 4500)
AiNodeSetFlt(light, "radius", 4)
# get the global options node and set some options
options = AiUniverseGetOptions()
AiNodeSetInt(options, "AA_samples", 8)
AiNodeSetInt(options, "xres", 480)
AiNodeSetInt(options, "yres", 360)
AiNodeSetInt(options, "GI_diffuse_depth", 4)
# set the active camera (optional, since there is only one camera)
AiNodeSetPtr(options, "camera", camera)
# create an output driver node
driver = AiNode("driver_jpeg")
AiNodeSetStr(driver, "name", "mydriver")
AiNodeSetStr(driver, "filename", "scene1.jpg")
# create a gaussian filter node
_filter = AiNode("gaussian_filter")
AiNodeSetStr(_filter, "name", "myfilter")
# assign the driver and filter to the main (beauty) AOV,
# which is called "RGBA" and is of type RGBA
AiArraySetStr(outputs_array, 0, "RGBA RGBA myfilter mydriver")
AiNodeSetArray(options, "outputs", outputs_array)
# finally, render the image!
AiRender(AI_RENDER_MODE_CAMERA)
AiEnd()
Message 6 of 10
n_rehberg
I haven't tried your code but from quick glance it seems you are mising all the universe creation and handling. That is some newer Arnold stuff that also made me stumble with some simple scripts I had.
Look at Stephens code to see how he creates an AiUniverse and passes that through his code.
Nico
Message 7 of 10
AaronWPowell
If a universe or session isn’t explicitly created Arnold will use the default ones. And it doesn’t fully explain why I can see the sphere, and the light, but the poly mesh is the only thing that doesn’t show up. The polymesh node is the only one not working as expected which is why I think I’m missing something with that specifically.
Message 8 of 10
n_rehberg
Ok. Sorry about that. It was just a first guess. My second guess is that Python and AiArrays combined suck.
If you look at the log it actually complains:
00:00:56 1567MB WARNING | resetting parameter vlist on (found: nans or infs)
If I create the mesh like this it renders for me:
nsides = [4]
AiNodeSetArray(mesh, "nsides", AiArrayConvert(len(nsides), 1, AI_TYPE_UINT, (c_uint*len(nsides))(*nsides)))
vlist = [-10.0, 0.0, 10.0, 10.0, 0.0, 10.0, -10.0, 0.0, -10.0, 10.0, 0.0, -10.0]
AiNodeSetArray(mesh, "vlist", AiArrayConvert(len(vlist), 1, AI_TYPE_FLOAT, (c_float*len(vlist))(*vlist) ))
vidxs = [0, 1, 3, 2]
AiNodeSetArray(mesh, "vidxs", AiArrayConvert(len(vidxs), 1, AI_TYPE_UINT, (c_uint*len(vidxs))(*vidxs) ))
uvlist = [0, 0, 1, 0, 1, 1, 0, 1]
AiNodeSetArray(mesh, "uvlist", AiArrayConvert(len(uvlist), 1, AI_TYPE_FLOAT, (c_float*len(uvlist))(*uvlist) ))
uvidxs = [0, 1, 2, 3]
AiNodeSetArray(mesh, "uvidxs", AiArrayConvert(len(uvidxs), 1, AI_TYPE_UINT, (c_uint*len(uvidxs))(*uvidxs) ))
Message 9 of 10
AaronWPowell
OH! That might be what I was missing. Let me test later tonight and I'll let you know if that solves the issue. Good eye, @n_rehberg.
Message 10 of 10
AaronWPowell
This worked! You're right, Arnold was being really finicky about the data type of the numbers going into the function. Explicitly converting to ctypes types fixes that.
