Noice won’t process full sequence
ep
ep
Hi there,
I´m having an issue with Noice (MAC version), in which it doesn’t recognize the frame sequence and stops at a certain point saying it is “Unable to load file”
I’m using a frame padding of 4 and it just seems that Noice can´t go beyond frame 0009 since at that point it starts looking for frame 10 (instead of 0010).
Here´s a copy of my log showing where this happens:
noice 5.1.1.0 [e338d869] - the Arnold denoiserLoading images...Loading file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0008.exr".Using feature AOV 'diffuse_albedo'Using feature AOV 'N'Using feature AOV 'Z'Working with 1 frame.Will denoise AOV "RGBA"Start denoising (patch radius 3, search radius 6, variance 3)Denoising RGBAFinished denoisingSaving image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0008_denoised.exr (1280 x 720 x 4)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr
------------------------ (9/122)
Loading images...
Loading file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr".
Denoising RGBA
Finished denoising
Saving image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009_denoised.exr (1280 x 720 x 4)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr
------------------------ (10/122)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr
------------------------ (11/122)
Loading images...
Unable to load file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr".
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_12.exr
------------------------ (12/122)
Loading images...
Unable to load file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr".
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13.exr
------------------------ (13/122)
Stephen.Blair
It works fine on macOS with the MtoA 3.2.0.2. I didn't try an older versions (you're using MtoA 3.0.1.0)
Are there any other files in that folder, along with the ones you want to denoise?
// Stephen Blair
// Arnold Renderer Support
ep
Hi Stephen,
Nope. The only files in that folder are the animation sequence that came straight out of Maya.
Guess I'll have to upgrade to the latest version.
Thanks for the help.
