Make object not reflect on selected object in Arnold?
litote
litote
Is there a way when rendering with Arnold in Maya to make one object not be reflected on the surface of another particular object? I know you can make an object not appear in all reflections universally, but can you specifically pick and choose certain objects to only be reflected on other specific objects ? You can do this in Cinema 4D.
zenop
You could create a separate render layer and:
  • Turn off the visibility in reflections for the object you don't want to see in the reflection
  • Turn off the primary visibility for all objects other than the "particular object"
