Is there any way to find this scene? I would like to make some tests with it in my hardware system
https://support.solidangle.com/display/AFMUG/Converting+an+Interior+Scene+to+MtoA
I think that this is an awesome result and the only question that rests is ...How long does this scene took to render with such a quality?. I would like to test it into my hardware system.
Do you know where can I find it?.
Besty regards.
T0M0X
Tthank you.
I thought that this was a demo scene or something like that : I think it's excesive to pay 120€ for this scene.
But it's supposed that with this option inside MAYA /Arnold, I will can import a scene already done...With what render engine? Any render engine?.
Thanks in advance.
lee_griggs
The scene was exported from 3ds Max (V-Ray) as a .fbx file and then imported into Maya. This shader conversion script was used to convert the shaders to Standard Surface.
I don't know what this means. Do you want a pre-built scene that is already setup for Arnold? If so, there is an interior scene here.
Lee Griggs
Arnold rendering specialist
AUTODESK
