indirect_diffuse AOV contribution
Message 1 of 12
Does the indirect_diffuse AOV contribute at all to a light's diffuse AOV?
If so, can this be turned off somehow?
Replies (11)
Message 2 of 12
Stephen.Blair
A light's diffuse AOV has both the direct and indirect contribution of that light.
If you don't want the indirect, can you use the light's diffuse_direct AOV?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 12
Maybe. We normally set our light diffuse LPE to:
> world_key5Light_diffuse C<RD>.*<L.'key5Light'>
What would be the LPE for the 'diffuse_direct' ?
Thank you,
Message 4 of 12
Stephen.Blair
The LPE for diffuse is C<RD>.*
and diffuse_direct is C<RD>.L
so for a light group AOV it should be C<RD>.<L.'key5Light'>
// Stephen Blair
Message 5 of 12
Hmm,okay, so you're leaving out the asterisk on purpose, yes?
So what would be the expression for the "indirect only" for a light group AOV?
Currently, i'm using:
> "world_key5Light_diffuse_indirect C<RD>[DSVOB].*<L.'key5Light'>"
but I get the feeling that's not correct...
Thank you,
Message 6 of 12
Thank you,
Message 7 of 12
Stephen.Blair
Yes, I left of the asterisk because if I look at the built-in LPEs:
diffuse_direct = C<RD>L
diffuse_indirect = C<RD>[DSVOB].*
diffuse_indirect_key5Light would be the indirect for that light group, so your custom LPE output should match that
// Stephen Blair
Message 8 of 12
I see, okay, Thanks for clarifying that.
So this job is older and we're still using 5.1.0.1 on it, though newer productions
are either on 5.4.0.2 or 6.0.1.0, and it is possible we could shift version for this
particular set of shots.
So that said, using these LPEs...
>> "diffuse_direct_key5Light C<RD>.<L.'key5Light'>"
>> "diffuse_indirect_key5Light C<RD>[DSVOB].*<L.'key5Light'>"
...yield two AOV layers which are identical. Why would that be?
Thank you,
Message 9 of 12
Just to add,
I've also found I get same results with 5.4.0.2 and 6.0.10.
Message 10 of 12
Stephen.Blair
You don't have to specify a light path expression, you can use the AOV names
  • diffuse_direct_key5Light
  • diffuse_indirect_key5Light
And Arnold will automatically create the light group AOVs
So in an ASS file, the outputs would be
  "diffuse_direct_key5Light RGB my_filter my_driver"
  "diffuse_indirect_key5Light RGB my_filter my_driver"
// Stephen Blair
Message 11 of 12
Stephen.Blair
For direct, the LPE
should be
 C<RD><L.'key5Light'>
The . is any event, so that includes too much
// Stephen Blair
Message 12 of 12
Thank you very much, Stephen!
