Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold General Rendering Forum
How to use 'sss_set_name' with Arnold API?
4 REPLIES 4
Le_Sep
694 Views, 4 Replies
While rendering several joined objects with the same SSS material, the border between objects is visible.
I know I have to use 'sss_set_name' to remove the seam but I don't know how to use it only with Arnold API.
In the kick -info polymesh or standard_surface, the keyword does not appear.
Many thanks for your answer.
You can see the effect on skull and neck of the character on picture below:
Tags (1)
Labels (1)
4 REPLIES 4
Le_Sep
in reply to: Le_Sep
picture without sss_set_name usage
Stephen.Blair
in reply to: Le_Sep
it's constant string user data, and it's named sss_setname
// Stephen Blair
// Arnold Renderer Support
Le_Sep
in reply to: Le_Sep
What is a constant string user data, and how to use it ?
Stephen.Blair
in reply to: Le_Sep
Check out the User Data API in the Arnold docs
Do you use any software, like Maya or Houdini? Export an ASS file to see what comes out.
Check out the SItoA opensource on the Autodesk github for examples.
// Stephen Blair
